Results 1 to 5 of 5
    blame me for missed rides
    Reputation: weather's Avatar
    do i need loctite for track cog on true track hubs?
    is loctite recommended or recommended against for mounting track goc on a true reverse-threaded track hub with lockring? thanks.
    Mar 2005
    Hell no
    Quote Originally Posted by weather
    Do NOT use loc-tite in that application. You've got a lock ring, thread lock compound is totally redundant and will be a huge pain in the ass later.
    In fact, just as when installing a freewheel, you should use grease, or even better anti-sieze compund.
    FTM
    FTM is offline
    Reputation: FTM's Avatar
    Sep 2004
    Quote Originally Posted by Fungazi
    Do NOT use loc-tite ... you should use ... anti-sieze compound.
    what he said.
    Reputation: ShivaSteve's Avatar
    Quote Originally Posted by FTM
    what he said.
    what he said again (I use an automotive anti-seize that I also use on spoke threads when building wheels.)
    grasso e lento
    Reputation: Dude's Avatar
    That is a BIG NO NO
    I ditto the ditto...... Do not use that AT ALL......
    -Dude
    If you wish to be out front, then act as if you are behind
  1. Do I have to just live with this?
    By SoloWithOthers in forum Singlespeed
    Last Post: 04-27-2005, 09:11 PM
  2. Surly cog proto here...
    By Soupboy in forum 29er Bikes
    Last Post: 04-16-2005, 02:10 PM
  3. Replies: 9
    Last Post: 02-21-2005, 09:19 AM
  4. Removing a track cog?
    By SSconny in forum Singlespeed
    Last Post: 07-28-2004, 11:25 AM
