Results 1 to 5 of 5
    E !
    E ! is offline
    Reputation: E !'s Avatar
    Jan 2005
    DMR sts tensioner
    Can you run a 1/8 chain with this? Also, does it adjust to chainline? Looking at a pic of it i cannot tell if the roller moves side to side???
    Thanks in advance!
    the - E - dog
    luddite
    Reputation: MadCowRider's Avatar
    Yes and yes
    Quote Originally Posted by E !
    Thanks in advance!
    Here's a pic of my Tension Seeker. The cage position is adjustable and can be locked in position with a set screw. The cage width has plenty of clearance with my SRAM PC-1 chain.
    E !
    E ! is offline
    Jan 2005
    Cool
    that's a nice shot. appreciate it.
    the - E - dog
    dutchie
    Thanks in advance!
    Not sure on the 1/8" chain. It's bassicly an MRP type roller that is mounted so if anyone has input on this.
    The roller can move a bit from left to right, it's a bit floating. So just eyeball the chainline and the small differnce will be taken up by the roller itself. But it's 5 mm max if not less that the roller can take up. A pic would explain this better though.
    I'll try to get a pic of my STS setup from above or below.
    Richard.
    Deadhead
    There are two different DMR tensioners. The one in the picture has no issues with a PC-1 chain, but the other one will not. The groove in the roller is not quite wide enough for an 1/8" chain to roll smoothly. Found this out the hard way on a friends bike.
    "If you can get both wheels sliding with no brakes, that's when you really know that you're cookin." Nathan Rennie
