Disc on problematic rear wheel- Mtbr.com
Results 1 to 5 of 5
    Reputation: running life's Avatar
    Hi,
    I'm fairly new to the SS world. I'm not sure if it's a global or personal problem, but every so often, my rear wheel is loosened up and moves forward, when I need to open the QR, and pull it back to place.
    I just got a pair of Magura Marta SL, and since I have nothing better to do with them, I figured it would be a nice addition to the bike. I'm wondering, however, if when the above happens, it won't break my rotor.
    Two questions, then:
    (1) Does this happen to everyone? Is there a way to solve the happy wheel issue?
    (2) If not, what do you do for disc brakes, if at all?
    Thanks,
    L
    bolt on
    bolt on rear wheel?
    Quote Originally Posted by buzzy
    bolt on rear wheel?
    I'm sorry, didn't understand the question..
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Quote Originally Posted by running life
    Some quick release skewers simply don't generate enough force to hold the rear wheel stationary in horizontal dropouts. Generally speaking, heavier is better with regard to QR devices and SS. Another option for the rear is to convert either to a bolt-on axle or replace the quick release skewer with a skewer with hex bolts instead. You can get these much tighter.
    use a QR with steel faces
    Use a QR with steel faces. Generally sturdier and the steel face "bites" better into the dropout metal.
