disc on fixed side of hub?- Mtbr.com
Results 1 to 5 of 5
    try driving your car less
    Reputation: jh_on_the_cape's Avatar
    Is there some way of putting a disc (for brakes) on the fixed side of a flip flop hub?
    Some adaptor, or maybe just a disc that is threaded and use a lockring? Will it line up? I ask because I have seen people do the other way: a fixed cog on the 6 disc mount bolt holes.
    It is for an ENO eccentric, if it matters. and yes, I will have to get the eccentric disc mount thingy.
    And I know I can get a new hub, but I would prefer some little $10 adaptor. But maybe it doesnt exist or is impossible for some reason.
    Only boring people get bored.
    hey you! use the search function!
    http://forums.mtbr.com/showthread.ph...sc+adapter+hub
    atomlab disc adaptor! $20 on their website.
    Reputation: itsdoable's Avatar
    Quote Originally Posted by jh_on_the_cape
    The AtomLab disc adapter is ment to go on a freewheel thread - the fixie side only has half as many threads. Although the adapter will go on correctly, you may run the risk of stripping the threads (aluminium on aluminium), I've stripped the fixie hub threads with a cog before - disc rotors are capable of more force.
    Quote Originally Posted by itsdoable
    OK, thanks for the headsup. no big downhills here, i weigh 180 and it's for the rear.
    this is all hypothetical at this point, of course. feasability study, of sorts.
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    Nice find, jh. Anyone have any idea on the feasibility of the disc brake adapter on a forward-facing dropouts like below (with or without those rack mounts)?
  1. Replies: 23
    Last Post: 05-13-2010, 07:08 AM
  2. Do I have to just live with this?
    By SoloWithOthers in forum Singlespeed
    Last Post: 04-27-2005, 09:11 PM
  3. Broke my Hugi 240 disc hub! Help pls!
    By 9W6VX in forum Wheels and Tires
    Last Post: 02-19-2005, 11:08 AM
  4. Deore disc brake with CODA discs?
    By nusbus in forum General Discussion
    Last Post: 07-09-2004, 06:42 AM
