Different chains for SS crank?- Mtbr.com
Results 1 to 9 of 9
    I'm trying to locate a 32 or 33 tooth SS crank. But the ones I've found use a "single-speed specific" chain such as the Middleburn Uno (I think). I'm assuming these chains are different from the ones on double cranks. Does anybody make a SS crank that uses a chain that can go with my cassette? Thanks.
    drev-il, not Dr. Evil!
    Reputation: Drevil's Avatar
    Quote Originally Posted by Buonarroti
    White Industries does. ENO. 3/32" chain works fine. I have a 32, and I know they make a 34. I don't know if it comes in a 33.
    Retro Grouch
    Reputation: aka brad's Avatar
    New question here. You should be okay...
    I'm not sure what you mean by a "double crank" or "a SS crank that uses a chain that will go with my cassette". Are you going to run a 1x7/8/9? Regardless most the chainrings, Middleburn included will accept a 3/32 (7/8/9 speed) chain. There are also 3/32 SS chains that simply aren't designed to shift (just a thinner version of a 1/8" BMX chain). If by "cassette" you mean a single cog, either a 3/32 or a 1/8" chain will work.
    1G1G, Brad
    Quote Originally Posted by aka brad
    I'm not sure what you mean by a "double crank" or "a chain that uses a chain that will go with my cassette". Are you going to run a 1x7/8/9? Regardless most the chainrings, Middleburn included will accept a 3/32 (7/8/9 speed) chain. There are also 3/32 SS chains that simply aren't designed to shift (just a thinner version of a 1/8" BMX chain). If by "cassette" you mean a single cog, either a 3/32 or a 1/8" chain will work.
    1G1G, Brad
    I'll be using the SS crank to go with my 9 speed cassette. What I discovered is that 32 (or 33) tooth crank combined with a 13x26 rear cassette gives me all the gearing range I need. A 32x13 (66 gear inches) is the highest gear I need. I am quite possibly the world's slowest cyclist.
    Retro Grouch
    Idea! Ahhhh...we refer to that setup as a 1x9..
    There is really very little difference (and mostly they are the same) between a SS crank and a muti-speed crank. The main difference seems to be the chainring where a non-ramped or pinned variety is preferred. Pretty much any crank can accept this kind of chainring. Some of the cranks, such as the Middleburn, Shimano XTR, or ENO are spiderless and have a very clean and Chi Chi look to them. You pretty much pay your money and take your choice. Occasionally you hear of a SS Chainring that doesn't like a 9 speed chain (I've heard some complaints about the Spot). Depending on your current crank, you can probably strip off the chainrings and install a 32 tooth non-ramp/pinned chain ring, without having to buy a new crank; Salsa makes a good cheap one and Surly says they will soon be releasing a stainless version.
    1G1G, Brad
    Contrarian
    Reputation: AndyArmstrong's Avatar
    I think that Unos are available in both 3/32 and 1/8 although I've only ever seen 1/8.
    Don't you guys ever talk about anything apart from bikes?
    www.shitshifter.com
    Reputation: Zen_Dude's Avatar
    Why?
    Why would you take off a pinned 32 to put on a SS 32, they work the same dont they for a 1x9.?
    Retro Grouch
    Silly answer..
    Quote Originally Posted by Zen_Dude
    The tooth profile of most ramped/pinned middle chainrings are designed to the drop the chain to the granny gear. You will usually notice some of the teeth are shorter then the others. Non pinned/ramped and especially SS chainrings have a more uniform tooth profile making a dropped chain less likely. This can be a major factor on a 1x 7/8/9 if the derailleur is removed, as the chainline will be off in all but one or two gears and there is nothing else but the teeth holding the chain on the chainring.
    1G1G, Brad
    Thanks for that answer, it makes sence. I guess I should get a SS sproket for the front. Im running a 1x9 and it does fall off sometimes.
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. New to SS What chain?
    By Zen_Dude in forum Singlespeed
    Last Post: 05-06-2004, 09:26 PM
  3. King SS hub and chain tugs?
    By pswann in forum Singlespeed
    Last Post: 05-04-2004, 02:29 PM
  4. SS specific chain rings?
    By FishMan473 in forum Singlespeed
    Last Post: 04-19-2004, 10:54 PM
  5. Calculating chain length for a SS conversion
    By od_the_roadie in forum Singlespeed
    Last Post: 04-02-2004, 03:58 PM
