current tensioner options?- Mtbr.com
Results 1 to 11 of 11
    Jan 2009
    the Chinese build thread made me ask a relevant question: are there any modern options for a tensioner that does not suck? I shattered the spring right away when I used a Surly tensioner, and anything that allows the chain to bounce around is super annoying.
    anything that works with a 142x12 thru axle and does not have a spring? maybe something that mounts to a BSA bottom bracket (which is still the only BB design that does not suck balls!)?
    it would be nice when considering new bikes on the market to rely on some sort of tensioner, as it would open up a ton of options. right now, all the tensioners I know of are lame, so I only consider bikes that have a built-in chain tensioning mechanism.
    would the "snail cam" design used on trials bike work on an XC bike?
    Reputation: socal_jack's Avatar
    Dec 2008
    That internal spring on a genuine Surly tensioner is pretty bulletproof, used one for awhile in push-up mode no issues. But actually shattering a spring? Doesn't sound like spring steel unless it was super cooled.
    Canfield Riot SS
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Jan 2009
    regarding the Surly tensioner, "shattering" was a euphemism. the spring broke after two rides. maybe that was a fluke, but it turned me off to spring-loaded tensioners. that, and the guards around the cog on it were so big that I could not use it in push-up mode without hitting the chainstay. so I ran it in push-down mode instead, and then the spring broke right away. I put the push-up spring in it and sold it immediately. this was over ten years ago.
    even if it works, your chain bouncing around like a jumprope sucks.
    Mar 2015
    alfine by shimano. basically a derailleur that does not move.
    https://www.amazon.com/Shimano-Alfin...fine+tensioner
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    This guy is asking too much for this, because it's a full conversion kit. If you find one of these as just the tensioner you wouldn't be sorry. I have two and they're dead simple, bullet proof, and set-and-forget.:
    (Soulcraft Convert) https://www.ebay.com/itm/Soulcraft-S...sAAOSwsUlamatC
    Attached Thumbnails Attached Thumbnails current tensioner options?-convert_01.jpg
    "And crawling on the planet's face, some insects called, The Human Race..."
    Downcountry AF
    Oct 2013
    Blackspire Stinger- fixed, BB mounted
    https://www.blackspire.com/product/s...ain-tensioner/
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Jan 2009
    I tried a BB-mounted Stinger. I could never get it to line up with my chainring because I am using a 2X crankset with a 1x1 drivetrain. I also remember it bottoming-out on my chainstay before actually tightening the chain. then I sat on it (not literally, you pervs) for a year before someone finally bought it for a few bucks. I really wanted it to work, too. I'd like to see some more BB-mounted options like that.
    Dec 2008
    Quote Originally Posted by mack_turtle View Post
    When you adjust the spring tension and damping on the Surly, the chain doesn't bounce but you need the oddball wrench. I ran mine without the guard as it wasn't necessary at all.
    Canfield Riot SS
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Downcountry AF
    Oct 2013
    Ghost ring
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    VEGAN ATHLETE Racing
    Reputation: vuduvgn's Avatar
    The guy from Helium Components had a super sweet one he was going to put into production but then he disappeared...I think he got a real job.
    I have a design for a simple one but don't know how to get it fabbed...
    Take a look at and consider "liking" our VAR Facebook and VAR Instagram pages.
    May 2016
    Quote Originally Posted by *OneSpeed* View Post
    I used the stinger on a Yelli Screamy, worked great. Had to adjust the grove a little bit to get it to like up with chainline. And i pushed down with it instead of pulling up due to the above mentioned issue with it hitting chainstay. But, it was bullet proof, worked great, and infinitely adjustable. You could also adjust the alignment by bending it side to side to suit your chainline.
  1. SS frame options...horizonal drops vs. chain tensioner
    By shackleton47 in forum Singlespeed
    Last Post: 02-16-2012, 06:45 AM
  2. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
  3. Tensioner or no tensioner?
    By passthepickle in forum Singlespeed
    Last Post: 12-18-2006, 01:34 AM
  4. Chain Tensioner options
    By kidwoo in forum Singlespeed
    Last Post: 03-18-2005, 05:55 PM
  5. TENSIONER vs, NO TENSIONER
    By erkstone in forum Singlespeed
    Last Post: 03-07-2004, 06:58 PM
Members who have read this thread: 9
