Curious but not commited.- Mtbr.com
Results 1 to 20 of 20
    AKA. Molasses
    Is there a way to temporarily fix the freewheel of a regular geared bike?
    I am curious about riding a fixie, but I am not ready to commit...
    JEB
    Reputation: AndrewTO's Avatar
    Mar 2005
    If you have a disc hub then you can get a cog that has the IS2000 brake rotor pattern in it. You obviously won't need the rear brake so .....
    Not 100% sure, but maybe there's some kind of kit you replace the actual freehub with?
    I ..... need ..... DIRT!!!!!
    ... and cookies. :D
    one chain loop
    Reputation: fishcreek's Avatar
    surly fixxer. no first hand experience about it, but would love to have one.
    everything sucks but my vacuum cleaner.
    AKA. Molasses
    Here is what I found:
    http://www.benscycle.net/index.php?m...b?disp_order=5
    Thanks for pointing me on the right direction.
    JEB
    Ovaries on the Outside
    Reputation: umarth's Avatar
    tomicog or surly fixer.
    Out spokin'
    Dec 1999
    Quote Originally Posted by Javier
    JEB
    Better:
    http://tomicog.blogspot.com/
    More tooth count options
    3/32 instead of 1/8
    More localish
    Same price
    --Sparty
    disciplesofdirt.org
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    I doubt you DONT have a disc hub but in case you dont id go with the fixxer
    "If women don't find handsome , they should at least find you handy."-Red Green
    On my Shimano hub I just bought an extra freehub and welded it solid.
    Reputation: boomn's Avatar
    JEB
    an additional disclaimer in case you didn't know: converting to a fixed gear is only possible if you have a singlespeed setup that does not rely on any tensioner
    AKA. Molasses
    Ok
    I am going to show here how much I do not know, please bear with me...
    Are you talking about the horizontal dropouts and such? I have a late 90s schwinn MTB with vertical dropouts and non replaceable derr hanger. Would the frame not handle well the torque of a fixie wheel?
    Thanks again
    JEB
    Thanks again
    JEB
    yes, singlespeed-specific frames, magic gear, or some other method of keeping the chain tight around the ring and cog in such a way that the chain goes from the ring to the cog on both sides without any other devices along the way. No derailleur or tensioner can be used to take up the chain slack
    it's not the frame that can't handle riding fixie. Riding fixie puts a lot of tension on both the top half of the chain (when pedaling forwards) and the bottom half of the chain (when braking with your cranks). Derailleurs and tensioners aren't designed to handle force on the bottom half of the chain and shouldn't be relied on for this
    Hopefully my explanation made sense because I couldn't think of the right wording
    Out spokin'
    Dec 1999
    Clarification
    Some folks consider an EBB or chain tugs "tensioners." Either can be used on a fixie.
    Boomn, this is not intended to conflict with your comments in any way. Only mentioned for clarification of terminology.
    --Sparty
    disciplesofdirt.org
    Quote Originally Posted by bad mechanic
    I thought you couldn't weld cast metal....hmmm...my teacher lied !!!!
    Quote Originally Posted by boomn
    Both the Eno Eccentric hub and the FC EBB are tensioners, yet they both can be used for fixed gear. However, you generally can't have a tensioner which pushes on the chain.
    Quote Originally Posted by nuck_chorris
    You only need to make it so it can't move, which isn't hard!
    i'm well aware, I just messed up the wording. I tried to address the details in my more recent post (but still messed up the use of "tensioner", bah!)
    now we're talking
    I'm just messing with you
    Reputation: wv_bob's Avatar
    That's what this guy said, and you might be aware of how well it worked out for him
    If not, then clicky for the wiki
    Chasing bears through the woods drunk with a dull hatchet is strongly not advised
    Ive also heard about people using JB weld to hold it still, is it plausible
