Results 1 to 7 of 7
    WAWE
    creaky phil titanium bottom bracket
    I have a new Phil titanium bottom bracket that creaks like mad.
    - Yes, I followed the directions.
    - Yes, it's all clean.
    - Yes, Loctite on the threads... all tried grease and anti-seize.
    - Yes, I've swapped the crankarms, frame, chainrings, bolts, etc.
    - Yes, I've had other (silent) Phil bottom brackets but they have steel spindle.
    - Yes, the crank arm taper is in decent shape.
    - Yes, I tried it on a different bike... still creaky.
    - Yes, tried spindle with nothing/dry, grease, and anti-seize... separately.
    - And yes, I swapped out a different bottom bracket (more than once) and it's silent so I'm sure it's the Phil.
    So is the creak coming from........ a) cup to cartridge, b) cup to frame (doubt it), c) crank arm to spindle (likely).
    Any ideas?
    ballbuster
    Reputation: pimpbot's Avatar
    I think....
    .... you need to start drinking more heavily.
    Team Captain
    agreed, pabst works wonders for creaks
    ballbuster
    and...
    Quote Originally Posted by ScaryJerry
    velocipede technician
    Reputation: hollister's Avatar
    Quote Originally Posted by aosty
    Any ideas?
    retaining compound goes between cup and bearing, not on the threads.
    cured my last creaky phil.
    looking for 20-21" P team
    mudnthebloodnthebeer
    Reputation: quaffimodo's Avatar
    Quote Originally Posted by hollister
    Do tell.....
    Also, the streets are full of horizontal dropouts...
    BSNYC
    Quote Originally Posted by quaffimodo
    dial up killer.
    like i said, its solved my creaks in the past
