Creaky eccentric bracket on el toro- Mtbr.com
Results 1 to 2 of 2
    Reputation: ryan123's Avatar
    Anyone else experience the creaking under pressure? Do I need to pull it out and regrease?? Any ideas would be great. Thanks!
    Yep, pull the ebb and regrease it. I've found the best luck using marine grade grease on my Salsa juan solo's ebb. I've used everything from phil wood, finish line, park, etc.....the marine grade stuff that I bought at a local boating shop just lasts longer and doesn't seem to get as filthy or let grit and grime penetrate as easily as the other stuff did.
