creaking sound- Mtbr.com
Results 1 to 5 of 5
Thread: creaking sound
    likes beer
    Reputation: manida's Avatar
    creaking sound
    So, my bike is starting to "creak" as I pedal. Im not sure if its the bottom bracket/cranks or what....seems to be getting worse though.
    thoughts?
    Reputation: Captain_America1976's Avatar
    Mar 2005
    the one time i have had creaking issues, it was bottom bracket related.
    Quote Originally Posted by manida
    thoughts?
    1) clean and grease EBB (if it's an EBB frame)
    2) clean and grease bb threads
    3) clean and grease bb tapers or whatever contact point with crank amrs
    4) clean and crease chainring bolts and contact points between chainrings and spider
    5) torque all of above properly
    6) creaking can also come from the spider/crank arm interface. clean and grease if possible, otherwise you can spray some WD-40 (gasp!) onto the interface to troubleshoot. If it stops creaking, you know that's the problem, the WD-40 will not solve the problem.
    Reputation: boomn's Avatar
    Check your pedals as well! There are bearings in them that need love too!
    I have replaced my bottom bracket and cranks and chainring only to find its my stupid pedals that creak
    Reputation: wonky57's Avatar
    Helps to isolate the squeak. Pedal out of the saddle, coast, take your hands off the bar, ride a wheelie. Listen for squeaks. That sort a thing.
