Creaking Carver- Mtbr.com
Thread: Creaking Carver
    Creaking Carver
    Does anyone have a good remedy for eliminating the "creaking" from a Carver EBB on a Gary Fisher RIG? From my understanding the Carver should have fixed the creaking issue, unfortunately mine is still quite noisy. I was thinking about trying some Fiber Gripô: Carbon Fiber Assembly Gel to lubricate and add friction. Suggestions appreciated.
    thanks
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Have you eliminated all other possible creaks? I had a creak coming from my rear skewer once that sounded like it was from my bb. Drove me crazy.
    I have greased all the dropouts points. But I haven't removed skewer completely. I will give that a shot. I have greased the splines and cog surface areas and the the front chain ring, spider and all the ring bolts. When I installed my new cranks I throughly greased everything there too. I'll try greasing the skewer if that doesn't work, then it will be new wheel set time.
    I fixed the problem. I bought a Vassago Jabberwocky.
