creak - top dead center, non drive- Mtbr.com
Results 1 to 6 of 6
    OK SS brainiacs, what's your diagnosis?
    I'm on a Yelli Screamy using a DMR STS tensioner.
    I get a little creak when my non-drive side crank passes through top dead center. It doesn't do this in the stand, but does do it while soft-pedaling through that part of the pedal stroke.
    My go-to moves for creak abatement are:
    1) remove BB, clean & grease, replace & torque
    2) remove crank arms, clean & grease, replace & torque
    3) remove chainring bolts, clean & grease, replace & torque
    I haven't done any of this yet. I'm curious what might be causing this creaking sound. If you were to do just one thing to eliminate such a creak, what would you do and why?
    Wanna ride bikes?
    Oct 2013
    as always tough to diagnose over the internet. I like your plan. going through the process will at lease eliminate the items you address. have you tried lifting up on pedals as you ride? pedaling without being clipped in on that side? keep experimenting to single it out as much as possible before tearing the thing apart.
    I've had a pedal that was properly torqued making a noise. i mentioned it to a mechanic, he grabbed a wrench and cranked it down tighter, noise gone.
    maybe check your cleats? lube pedals?
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: AlexCuse's Avatar
    I have a problematic BB (external cup bb30) so thats where I would look first. But once you're doing that it doesn't really make a lot of sense to skip the others.
    If I could do just one thing to fix it, it would be to replace with a white industries crank and a square taper BB. Someday...
    Yeah I only carry cans cause I'm a weight weenie.
    Armature speller
    Sep 2004
    I had no noises until I replaced the chain ring.
    Now a single creak per rev even at low load.
    Only things touched were the chain, chain ring, ring bolts and re-tensíoning the DMR STS.
    Well, I found that my Time pedals were a little loose, so I tightened up the end caps, and then popped them off and greased up the threads and replaced them. No creaking on a 30 second ride on the street, will see what happens when I ride this evening.
    Jun 2015
    Quote Originally Posted by grundy View Post
    Pedals tend to "pop" when lube or looseness is a problem. It's most likely your seat.
  1. Replies: 23
    Last Post: 12-10-2014, 08:51 AM
  2. gates center track belt drive
    By febikes in forum Singlespeed
    Last Post: 07-10-2012, 02:01 AM
  3. solved, drive train creak
    By kingair in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-18-2012, 10:25 AM
  4. solved, drive train creak
    By kingair in forum Niner Bikes
    Last Post: 05-17-2012, 10:09 AM
  5. i-drive creak creak creak
    By slo65 in forum GT
    Last Post: 04-18-2011, 07:54 AM
