Crave SL Chainring Upgrade- Mtbr.com
Results 1 to 7 of 7
    Back at it
    Reputation: storz's Avatar
    Jan 2011
    What is a good 32t chainring to use on a stock Crave SL drivetrain? The bike comes stock with an 8spd KMC chain. I am 210lbs and a masher, the climbs here are short and steep, lots of out of the seat full power bursts. Looking for strong
    Will a Raceface narrow wide work with an 8spd chain?
    Ellsworth Evolve SST.2
    Oct 2015
    Doval or Absolute Black
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
    Downcountry AF
    Oct 2013
    Quote Originally Posted by buell View Post
    not doval, it's a POS.
    AB, Raceface, Wolftooth all make good rings. yes, the Raceface NW will work with an 8 speed chain.
    you should consider replacing your chain while your at it.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Back at it
    Jan 2011
    Just pulled the trigger on a stainless Chris King 20t cog and Raceface 32t narrow wide ring. The bike only has 30 miles on it so the stock chain is good to go still. Also bought a little spacer kit to make sure the chain line is correct since the Chris King cog base is a little wider than the stock one.
    Sent from my Nexus 5X using Tapatalk
    Sep 2014
    I'm of similar weight and us Clydesdales will wear through AL chainrings too quickly. I run Surly SS rings on my SSMTB and SSCX and will never go back to AL. Also, I strongly recommend the KMC Z610HX chain for us mashers. This combo is up to the task for heavy strong riders.
    Cannondale CAADX 105 - SS build
    Raleigh Willard 2
    Cannondale CAD3 SS 96er build (circa 1997)
    Low speed, High Drag
    Reputation: kevhogaz's Avatar
    I'm about 225,and I put an E*13 32t on the front, and an Absolute Black 20t cog on the rear. I'm running a SRAM PC-951 chain. So far, I'm liking them both. However, I've only got about 70 miles on the combo, so can't speak much for the wear, yet.
    I need a cool saying to put here.
    Reputation: madsedan's Avatar
    Aug 2010
    I'm 235# and running a Absolute Black front and rear with their 32t oval front ring and 18t rear cog. About to install a KMC X10sl I bought on closeout from price point for next to nothing, will report back.
    Hardrock 29er, Niner EMD9, Cannondale F29, Camber Expert, 650b Nickel all gone.
    2014 Giant Anthem 27.5 here.
  1. crave forks upgrade
    By Sid79 in forum Specialized
    Last Post: 08-28-2015, 05:42 PM
  2. Hmmm...15 Crave vs 15 Crave Comp?
    By MJFNH in forum Specialized
    Last Post: 03-03-2015, 05:33 PM
  3. Crank upgrade for Crave SL 2015
    By ybh70 in forum Singlespeed
    Last Post: 01-14-2015, 09:37 PM
  4. Suntour Chainring Upgrade
    By Mirkin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-28-2012, 06:24 PM
  5. Chainring Upgrade
    By biggrumble in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-21-2012, 05:16 PM
