Cranks and chainline....- Mtbr.com
Results 1 to 2 of 2
    Reputation: Nubster's Avatar
    Building a SSCX bike. It's a 12x142. I'm looking at some SRAM CX1 cranks and they say:
    45.5mm chainline is compatible with 130 or 135mm spaced rear dropouts
    So what happens if I use this crank on my frame? The rear hub is a standard hub so plenty of room to move the cog around...but would I be better to look for a different crank?
    Would a crank that's 2x be better or any different? I'd be setting it up with a direct mount chainring if that matters.
    The whole crank and bottom bracket standards all over the place just has me flustered today so I want to make sure I'm not making another mistake ordering the wrong crank.
    Super snowflake = when an avatar offends you so much you have to cry about it and report it to admin. Life must suck for you.
    Oct 2015
    142 is the same as 135. the only difference is that there are 3mm notches on each side of the dropouts so the hub can slide into place easily.
    2003 Kona A
    2005 Kona A
    2012 Cannondale Hooligan
    2016 Salsa Deadwood
  1. Octane One Orbital Hub & D1 Cranks - Chainline
    By AndyTomlin in forum Singlespeed
    Last Post: 12-21-2011, 04:53 PM
  2. Octane One Orbital Hub & D1 Cranks - Chainline
    By AndyTomlin in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 12-15-2011, 12:44 PM
  3. chainline of Shimano M760 series cranks
    By gabbard in forum Singlespeed
    Last Post: 07-27-2011, 07:28 AM
  4. 1x9/10 and 2x9/10 cranks with adjustable chainline
    By rynogee in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-15-2011, 09:48 AM
  5. SS Cranks that work with Rohloff chainline?
    By mbeardsl in forum Internal Gear Hubs
    Last Post: 03-09-2011, 05:44 PM
