crank question- Mtbr.com
Results 1 to 6 of 6
Thread: crank question
    single speeder
    crank question
    Guy at work gave me an older mountain bike and I am tearing it down to build a SS. The front gears are riveted on. Can I drill them out and use the middle gear or bolt on a new ring?
    Did I catch a niner+?
    I think if you drill it out that will be the end of the chainring set. A new set of Shimano LX are about $79 on jensonusa.com
    single speeder
    I am really just trying to get away without buying new cranks.
    Grind off the teeth on the outer ring and u got yourself a bashguard. Do whatever is neccessary to take off the granny, provided it's not on the same rivet as the middle. Unless you wanna change the the chainring size... Now that is a different story.
    Reputation: Just1Gear's Avatar
    Jan 2011
    Quote Originally Posted by Kaizer View Post
    ^^^This^^^ I've done it before and it worked pretty well
    Dec 2010
    Or just run it as a 3 ring crank...or try to find a bike or crank with bolt on rings..
  1. BB-Crank question
    By rjg5 in forum Shimano
    Last Post: 09-16-2010, 03:03 PM
  2. FSA crank question
    By PRANA FEROX in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-31-2008, 08:49 AM
  3. Yet another crank question
    By crashtestdummy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-17-2008, 03:38 PM
  4. question about my crank
    By defcon4 in forum Transition Bikes
    Last Post: 12-05-2007, 05:17 PM
  5. BB/crank question
    By jsd in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-21-2004, 05:43 PM
