Crank question- Mtbr.com
Results 1 to 3 of 3
Thread: Crank question
    190lbs of climber
    Reputation: Menso's Avatar
    Crank question
    Can I use any square-tapered cranks on a square tapered mountain bike BB?
    Specifically, can I use an any cheopo square taper ROAD crankset I find on Ebay on an old Trek 4300 that's being built up as a SS get-to-school bike? I believe it has some crummy shimano or something square BB.
    Francis--If you see this: I'll drop the check off from Downieville tomorrow since I keep on forgetting to do so.
    ye' old trailblog: www.most-excellent-adventures.com THE BAY AREA... WHERE IF IT'S FUN, IT'S ILLEGAL
    King Pin
    Reputation: xrmattaz's Avatar
    Good job!
    Sure you can. One of my beater commuters has an old Dura Ace crankset converted to single-ring use. Works dandy!
    Reputation: bikeny's Avatar
    Yes and no!
    You can use any Shimano or Shimano compatible square taper crank(almost everything), but you cannot use a Campagnolo crank, which I believe uses a different standard.
    Mark
  1. Greasing bottom bracket spindle?
    By Belfrey in forum Tooltime
    Last Post: 07-24-2005, 11:09 PM
  2. Problem w/ Truvativ crank arms and BB
    By mvanderb12 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-13-2005, 11:32 AM
  3. 4 crank questions
    By peteer01 in forum General Discussion
    Last Post: 05-13-2005, 11:12 AM
  4. Extralite will introduce an Intergrated Crank/BB
    By DIRT BOY in forum Weight Weenies
    Last Post: 10-02-2004, 02:42 AM
  5. What's the white goop on my bb spindle?
    By Spoiler in forum General Discussion
    Last Post: 02-19-2004, 11:16 AM
