Crank/Chainstay clearance- Mtbr.com
    I just finished my build of a ti ss and am having an issue with the crank arm grazing the chainstay when I stand and climb steep stuff. I'm running a well centered Phil's BB which gives me about 1/8 inch of crank/chainstay clearance on each side. Apparantly it's not enough. Any recommendations on spacing?
    Out spokin'
    Dec 1999
    I feel most comfortable with about 1/4 inch of space in there. I just installed a new crank on my old bird and had to go from a 113mm BB spindle (old crank) to a 122.5mm spindle (new crank)! Whoa!
    --Sparty
    disciplesofdirt.org
    Reputation: dirtdirt223's Avatar
    Mar 2006
    sounds like you might need a bb with a longer spindle.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by glenndandy
    Whatever it takes for the crank to not rub. I have bikes with as little as 2mm of clearance with no rub and others have needed 5mm or more.
    mtbtires.com
