Crank and Bottom Bracket Quest.- Mtbr.com
    I just bought a 2011 Trek Superfly SS Frameset, Wondering if the Cannondale Hollowgram SL cranks or any BB30 cranks would fit the standard 73mm bottombracket, Is this possible?
    nothing to see here
    Reputation: Stevob's Avatar
    I would think not. BB30 cranks require a 42mm ID bb shell to fit the bearings. In short, the bearings wouldn't fit, and they are press fit anyway.
    I see hills.
    I want to climb them.
    It may with the e.13 or Zipp Zuma Quad BB that take 30mm spindles.
    Reputation: Shalom's Avatar
    Nov 2008
    This might work...?
    Ned's SS Rockhopper with OS cranks
    "The most interesting component was the S-Works FACT OSBB carbon crankset with a Rotor chainring that fitted the threaded ecentric bottom bracket through the use of Zipp’s Vuma Quad Bottom Bracket. The Zipp external bearing BB retrofits the crank’s 30mm axle to a standard bottom bracket shell."
  1. Bottom bracket and crank ?'s
    By nelsonccc in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-27-2011, 06:03 PM
  2. crank and bottom bracket help
    By what in forum Specialized
    Last Post: 08-13-2007, 09:38 AM
  3. JIS crank on ISO bottom bracket?
    By Ottoreni in forum 29er Bikes
    Last Post: 11-27-2006, 03:00 PM
  4. Quest for a bottom bracket
    By HJB in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-04-2006, 06:44 PM
  5. crank and bottom bracket!
    By wolfeinstein in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-23-2005, 02:37 AM
