Couple of Brake Upgrade Questions- Mtbr.com
    Custom User Title
    Reputation: Pudgerboy's Avatar
    Nov 2006
    Forgive me if this is obvious stuff but i was wondering -
    1. Can i upgrade my front shimano deore hydraulic disc rotor (which is a 160mm rotor) to a 180mm rotor on the front without any change?
    2. Can i upgrade an old frame with canti mounts and upgrade them to V-brakes?
    thanks!
    Pete
    Dec 2005
    Quote Originally Posted by Pudgerboy
    1. Can i upgrade my front shimano deore hydraulic disc rotor (which is a 160mm rotor) to a 180mm rotor on the front without any change? you also need an adapter!
    ofcourse you can!
    thanks!
    Pete
    See above!
    Custom User Title
    Nov 2006
    Hi Marinti, Thanks for your reply - that was fast! I assume you need an adapter to redress the larger diameter of the rotor so it aligns correctly on the pads?
    edit - found what i need! thanks!
    Custom User Title
    Nov 2006
    here's another - I take it i can also upgrade it to a super fly rotor too? all these bike with their funky rotors - I want one!
