Converting to SS, what do I need?- Mtbr.com
Results 1 to 5 of 5
    Really thinking of converting my '08 Stumpjumper 29er Comp (it's a hardtail). It has sliding dropouts, so I'm told I don't need a tensioner. What do I need for the conversion? I'd like to use SS cogs/chainrings to eliminate the shiftgates, and also to save my original drivetrain to go back if necessary. Is a SS chain necessary or just a good idea?
    What gear ratio? On the night-ride last night, someone said 32/20, does that sound right?
    Thanks.
    The link on the upper right of the single speed forum home page is a good place to start.
    Reputation: fixedforbroke's Avatar
    gearing depends on the terain, it also depends on the parts you use as to wether you need a different chain... bad mechanic is right... you should click around on the single speed forum and see what you can see
    Req. Disclaimer: I sell Giant, Trek, and Electra bikes.
    Quote Originally Posted by ErrantGorgon
    The no-brainer store called, they want their question back.
    Where do you usually sit in your cassette? I'd pick somewhere in the middle and go from there. 32/20 isn't a bad place to start. I'd pick up an 18T cog too. All depends on what kind of terrain and how strong of a rider you are.
    Livin' the dream.
    Feb 2007
    Single Speed Chainring, Cogs, Spacer Kit & Chain
    I have everything that you need to convert your bike to a SS.
    http://www.socaltrailriders.org/foru...s-spacers.html
