Converting to Singlespeed- Mtbr.com
Results 1 to 15 of 15
    May 2010
    Is it possible to convert any bike to a single speed? What do you need to do to convert it?
    Thanks for any info.
    Cajones.
    And Single speed conversion kit. ENO hub, FC EBB, derail tensioner, magic ratio, or weld on new SS drop outs if the bike comes with vertical ones.
    openwound
    Reputation: voodoochild's Avatar
    Yeah, pretty much any frame can be run with just one gear. The simplest or perhaps cheapest way to try it would seem to be using a chain tensioner. I only point to that "kit" as it's the first one I found, I'm sure that the helpful folks here can chime in on which tensioners to use/avoid.
    But the general idea is to get a single cog out back, and lacking track/horizontal dropouts, a device to manage chain tension.
    Yes, you can get lucky and find the "magic gear" for your frame and components, but that can take a little bit more time and/or patience to figure out.
    The other stuff that p_nut refers to, such as the eno hub or the Forward Components eccentric bb start to get a little bit more spendy -- and perhaps a little bit more on the commitment end of the spectrum.
    Try it, you just might like it.
    May 2010
    So I would need a new hub for this?
    PSYCHOLUST
    Reputation: scyule's Avatar
    Quote Originally Posted by minnewasta_angler
    NOPE... Just pull your cassette, install a single cog and spacer set, replace your deraileur with a tensioner ,
    If your bike is a 3X9 MTB, remove you big ring and your granny and run your chain on the middle ring and single cog out back.
    A suggestion.... get the spacer kit with a stack of rings rather than one with a single outer and inner spacer... you have to get the chain aligned between the ring at the front and the cog at the back
    If you'd like to see if your frames chainstay length is JUST RIGHT to run a "magic gear" try this sight.... My first conversion worked with this.
    http://eehouse.org/fixin/fixmeup.php
    May 2010
    Will it work if I have the really old style of hub. Will it still work? I cant find a picture of this hub.
    one chain loop
    Reputation: fishcreek's Avatar
    everything sucks but my vacuum cleaner.
    May 2010
    Also, what is the difference between a coaster and fixie?
    Reputation: ernesto_from_Wisconsin's Avatar
    I wish I would have taken pics today of what I did. I bought a a Raleigh road bike from a rummage sale. It wasn't on sale. I kept looking at the bike hanging in their garage, and it was very dusty. Caked on dust. I told the lady I'd give her $40 for it. I knew it was my size, and the bike is in MINT condition. She's in her 50's and told me she's not ridden it in years.
    So I brought it home. In 10 minutes, it was all taken apart. My new rainy day SS bike. Pics to come.
    Any bike can be single speed. ENO, fake tensioner (using a derailleur as a tensioner), horizontal drops, etc. Any bike.
    Jessica Alba, if you are reading this, you got a nice smile.
    C'mon, dude. I know you've got at least SOME mental competence to search some of this stuff.
    http://en.wikipedia.org/wiki/Fixed-gear_bicycle
    Drinking the Slick_Juice
    Reputation: nuck_chorris's Avatar
    Do what the Dope Fish told you, read all of that information
    "If women don't find handsome , they should at least find you handy."-Red Green
    Ovaries on the Outside
    Reputation: umarth's Avatar
    Quote Originally Posted by p nut
    Dunno. The interwebs is scawy.
    Quote Originally Posted by ernesto_from_Wisconsin
    Thanks.
    one chain loop
    Speaking of Raleighs, I scored a "78 Grand Prix for 10 beans this morning. Will SS it for my old pops, he hates shifting. Pics to follow after oiling my muscular body.
    Ride,Smile, Pedal Damn it
    Reputation: henrymiller1's Avatar
    I remember an article by Keith Bontrager about converting to SS. It was very helpful and down to earth. I used it to convert my first. I remember using a grinder to cut off the big chainring.
    Go to : http://www.bikemagic.com/maintenance...-pile/363.html
    "Ride, smile, and pedal damn it."
