Converting old Surly 1x1 hub to QR- Mtbr.com
Results 1 to 5 of 5
    Mtn View, CA
    Reputation: gddyap's Avatar
    I have an old Surly 1x1 rear hub that uses hub nuts. My bike has vertical dropouts and I would prefer to use a QR instead of having to bring a wrench to remove the wheel to fix a flat. This hub uses a proprietary axle so there isn't anything available to convert to QR nor does Surly offer anything. Their current hubs can be converted. So I decided to do it myself.
    Here is the hub. Surly 1x1 with a Rhinolite rim. I use a Shimano freewheel.
    Axle removed. Other bearing is still in hub.
    Hub with bearing removed.
    I determined that the axle length needed to be 145mm (135mm drop out spacing plus 5mm per side) so I had to cut it to length. I rough cut both ends with a Dremel to get close to 145mm and then chucked the axle in my mini-lathe to cut and face to final length. Added a chamfer to the threads to make it easier to install the bearing nuts.
    I don't have a drill long enough to go all the way through the axle so I have to drill halfway through both sides. I used a #7 drill (5.105mm) and did one side. Unfortunately when I started on the other side I broke a clamp bolt in the lathe. So I'll have to fix that before I can finish. I'll take a picture of drilling and of the final results. I also found that Surly is now using axle bolts instead of nuts with the hollow axle being threaded. I may do the same so that I can switch from QR to bolts.
    I have come here to chew bubblegum and kick ass... and I'm all out of bubblegum.
    The need for singlespeed
    Reputation: zaskaranddriver's Avatar
    Nice work--hope it works out for you.
    Aren't Surly axles all 10x1? You could just order a very common replacement axle. Probably under $10 at your LBS.
    Mtn View, CA
    From the Surly website FAQs:
    Can I change my solid axle New Hub into a quick-release?
    ... If you have an OLD hub of ours that is silver or black and says "1x1" on it, you have an old beast with a proprietary axle that cannot be replaced (because it is not made anymore.) ...
    Dec 2010
    Did this project ever get finished?
