Converting crossmax wheels- Mtbr.com
Results 1 to 5 of 5
    I have a set of crossmax I would like to convert to solid axel bolt on.(terminology??)
    Does anyone know if it is possible. I saw a set-up made by Surly, but it said it only works on shimano hubs. Thanks for your help. BK
    -> SickLines.com <-
    Reputation: mtb_biker's Avatar
    Quote Originally Posted by mtbkendall
    You can buy spacers to use a single gear, but i dont' think they make bolt adapters for crossmax's. You could sell the crossmax and buy a real single speed rear wheel
    Fight the Kakistocracy!
    Reputation: veelz's Avatar
    bolt on QR
    Control Tech used to make QR skewers that were not QR, but bolt on, Delta makes a set, here is the link to a LBS's site with a pic. Crossmax, at least mine, there is no way you can replace the axle without making a new one, and there are simpler solutions than that.
    veelz
    Gravity, not just a good idea, it's a law.
    The only one consistently and constantly applied, no exceptions.
    Ron
    Ron is offline
    Reputation: Ron's Avatar
    Hey Brady, You could get the surly chain tugs they have an adapter that allows the use of a QR. That should keep the axle from slipping.
    Ron
    Ron is offline
  1. Disc wheel build : lacing question
    By Nick. in forum Wheels and Tires
    Last Post: 03-03-2004, 07:03 PM
  2. Will Michelin DH work as tubeless on Crossmax XL?
    By BanzaiRider in forum Downhill - Freeride
    Last Post: 02-27-2004, 11:52 AM
  3. Honest opinions on Crossmax SL Disc UST?
    By - Jeremy - in forum Weight Weenies
    Last Post: 02-26-2004, 05:13 PM
  4. Do wider rims = stronger wheels?
    By Friar in forum Wheels and Tires
    Last Post: 02-20-2004, 11:54 PM
  5. Recommend a wheel set fit for a Clydesdale
    By martinman in forum Wheels and Tires
    Last Post: 02-04-2004, 08:26 PM
