converting cross bike to single speed- Mtbr.com
    Here is my project - converting an old Ibis Hakkalugi to a single speed. It is currently a triple up front with STI shifters. I am trying to figure out what the whole project is going to cost, so here is my list of parts:
    Required:
    Chainring - 110 BCD, 40 or 42 tooth
    Single chainring bolts
    Rear wheel, Eno hub
    Non-STI levers (brake only)
    Freewheel
    Optional:
    Chainring guards
    What am I missing? I do not want a singleator, so even though the Eno hub is expensive, I like the idea of the clean lines, and also this will be my mud racing bike - big tire clearance, no derailleurs. What is the usual cross singlespeed gearing - 42 up front and something like a 16, 17 or 18 in the back? How much chain will the Eno hub take up - will it allow me to swap rear freewheels?
    So many questions...any help is appreciated.
    Steve
    Apr 2005
    If you're looking to do this on the cheap, why not simply yoink off the granny gear and grind the teeth down on the big ring to turn it into a bash guard?
    Brian, there's a message in my Alpha-Bits, it says "OOOOOOOO"
    Peter, those are Cheerios
    Gears, we don't need no steenking gears!
    no bashing here
    Quote Originally Posted by MacTech
    This is a cross bike, so if I have bashed into anything with the ring, it is a barrier and bad things are happening. My only reasoning for the chainring guards is to keep the chain from coming off. Then again, maybe they should be called "chain-coming-off guards".
    Steve
    Mar 2005
    ... and if we just ... Tips etc
    Quote Originally Posted by gabbard
    Steve
    I have raced a single speed cross check for a couple of years now and I run a 39-18 gear for cross racing, you might try a 39-17 if you are strong and on a flatter course, but also don't forget to factor in mud if present, at the nationals, in 2003 in Portland several of the single speed racers geared up cause the course was flat, but at race time most of the course was 4-8inches deep of mud, the single speeders myself included did a lot of running. If you are using a 110 crank you might need to use a 36t front and a rear which would give you a similiar ratio, like a 16 maybe. YOu shouldn't need a bash guard on the single as long as you have a good chain line, but if you don't use one you will need a set of the short chainring bolts, I use one cause it is easy to hit a 39t if you are out trail ridding, and I like the looks. I know some people who have used the eno with no problems, even having a different fixed gear on the flip side, with out problems, I think that a 1or 2 tooth difference shouldn't be a problem. Hope this helps
  1. WalMart bike kicked my Ibis's ass!!
    By Itripper in forum General Discussion
    Last Post: 03-08-2006, 02:38 PM
  2. Mountain bike jargon/ lingo
    By bstguitarist in forum Beginner's Corner
    Last Post: 05-26-2005, 12:02 PM
  3. Forks, Frames and Five Hundred Dollars.
    By AdamOn6thStreet in forum Clydesdales/Tall Riders
    Last Post: 02-25-2005, 10:10 PM
  4. If you need to know this.
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 12-24-2004, 09:40 AM
  5. Lance's Austin "29er" revealed
    By ncj01 in forum 29er Bikes
    Last Post: 08-28-2004, 08:14 PM
