Converting a 27 speed to SS.- Mtbr.com
Results 1 to 3 of 3
    Reputation: standard235's Avatar
    Zach(standard235) here again with another question.
    Seeing as I only ride urban, I was looking to see how I would go about switching to SS from 27 speed.
    If it is a lot of work, then count me out.
    If it is easy, then woohoo.
    So, how should I go about doing this?
    EDIT: This is also for a FS bike. Would that be a bright idea?
    I have never heard of a SS FS bike before.
    Reformed car junkie
    Sep 2004
    Quote Originally Posted by standard235
    Ill chime in cause no one else has. The problem with a SS FS is keeping the chain tensioned as the rear triangle goes through its motion. And none of the conversion tensioners have enough spring something or other(im not sure if its a spring tenstion issue or a spring range issue(like how much variation it can handle)).
    So maybe go with a single chain ring up front with a retention system like whats available from e13 and keep your gears in the back.
    So it sounds like it probably wouldnt be worth it for you, get a HT and its easy. I did a conversion on a coworkers bike in about and hour and a half.
    Alright... I might just say **** it with this MTB and see if I can sell it...
    Sell it and buy my friend's Specialized SS... .with the Dirt Jumper 3 forks. Yummy.
  1. what is sierra club's stance on wilderness?
    By head in forum Riding Passion
    Last Post: 03-01-2005, 07:03 AM
  2. Everything you need to know about the PIKE's Motion Control Damping!
    By MicroHuck in forum Shocks and Suspension
    Last Post: 02-21-2005, 10:25 AM
  3. Very Old Shimano 7 speed replacement
    By NFields in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-27-2004, 04:30 PM
  4. 8 speed vs. 9 speed spacing (where is it)
    By Island Ruffian in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-08-2004, 08:49 PM
