Convert a SS to a 2 X 10?- Mtbr.com
Results 1 to 13 of 13
    Aug 2015
    Sorry to piss off SS fans, but I was wondering about converting a SS to a geared MTB. I have my eye on a 2008 Felt Nine Solo. Thought maybe I could buy a groupset and go geared. Worried, b/c the Felt 2008 catalog states that it has "Cold-Forged Vertical Single Speed Dropouts". Also has an "eccentric bottom bracket," and I don't know what that means. Please advise. Name:  felt_ninesolo_08_m.jpg
    Apr 2015
    No clue to the bike in question, but why even consider 2x drivetrain when 1x is all the rage these days? I can see why it's populair to do without the front derailleur.
    WillWorkForTrail
    Jun 2012
    Why not just buy a bike with a 2x10 drive train? Add up the cost of a decent drive group, figure in the cost of the Felt, and you'll find your budget is probably sufficient to just buy a decent bike that comes with what you want.
    Wanna ride bikes?
    Oct 2013
    i would just look for a geared bike. it will likely cost you less and be a lot less hassle.
    if you buy the single speed (assuming it is compatible with rear derailleur and cassette) you will also need to build a new rear wheel and buy new cranks and a full drivetrain.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    FYI the "vertical dropouts" are like the dropouts on a geared bike where the rear axle drops into. Non-adjustable in other words. This is opposed to horizontal dropouts which are slots that allow moving the axle forward or backwards to adjust chain tension, like the single-speed kids' bikes at Walmart.
    The "eccentric bottom bracket" permits chain adjustment. The crank is not mounted in the center of the bottom bracket shell, but offset a bit. By rotating the bottom bracket, you move the crank forward or backwards.
    This is the arrangement used to adjust the front chain on a tandem BTW.
    Jan 2009
    I think setting up a front derailleur on a bike with an eccentric bottom bracket could be a giant pain. 1x10 would not be so bad though, if a dropout with a derailleur exists that has a derailleur hanger on it. otherwise, the cost of buying a new rear wheel, derailleurs, chain, cranks cassette, and shifters will put you well on your way to a new bike. better to cut your losses and sell that bike to fund the new one.
    Reputation: Andy R's Avatar
    Nov 2008
    It may well have normal vertical dropouts but most probably won't have a rear mech hanger if it's designed as a dedicated singlespeed.
    So you'd have to find a way around that, for a start.
    Aug 2015
    Okay--maybe a 1 x 10. But will a cassette fit back there??
    Quote Originally Posted by mack_turtle View Post
    Thanks for the replies, folks!! I'm learning so much.
    I love the idea of doing a 1 x 10 . I can get a nice XT 1 x 10 groupset for just $200, so why not? But will a cassette fit? Here's a pic: Name:  FeltSSrear.jpg
    Reputation: jmmUT's Avatar
    Quote Originally Posted by Flydyl View Post
    Would need to have a better look at your rear hub. If it's a dedicated SS hub (which it kinda looks like- a SS cassette style specifically) then you can't fit a 10 speed cassette on it and so would need a new rear wheel or hub.
    Aug 2015
    Yes--I figured I might need to rebuild the rear with another hub (or find another wheel). Is there any chance that the frame is too narrow to accommodate a cassette?
    Aug 2015
    Two more photos, if it helps you, good people:
    Convert a SS to a 2 X 10?-feltsolorear.jpgName:  felt_ninesoloframe_08_m.jpg
    Wanna ride bikes?
    Oct 2013
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Reputation: life behind bars's Avatar
    May 2014
    Internal gear hub would be the easiest way to do it without having to cobble something hideous. Have a look around here:
    Internal Gear Hubs - Mtbr.com
  1. Would you convert to 27.5?
    By aevanlloyd in forum Pivot Cycles
    Last Post: 01-11-2014, 07:09 AM
  2. ABP Convert
    By u1-2go in forum Trek
    Last Post: 04-16-2013, 09:05 AM
  3. Replies: 6
    Last Post: 10-05-2012, 11:12 AM
  4. Should I convert it into a SS?
    By YYZ in forum Singlespeed
    Last Post: 08-27-2012, 11:06 AM
  5. Convert To Ss Or Fix 3x7
    By RIDDICKDUX in forum Beginner's Corner
    Last Post: 04-26-2011, 09:43 AM
