Convert a road wheel to MTB spacing- Mtbr.com
Results 1 to 7 of 7
    Reputation: oldskoolboarder's Avatar
    Forgive the newbieness, I tried looking at the SS FAQ and Sheldon's site but couldn't find an answer.
    I've never worked on wheels before but thought I'd give it a shot. I have a rear wheel w/ a shimano freehub that I want to convert for use on a frame spaced for 135 mm.
    1) Is this as simple as changing the axle to a longer one, assuming I center it correctly?
    2) Any sites that explain how to change the axle?
    Reputation: shiggy's Avatar
    Dec 1998
    If it is a Shimano hub it is pretty easy. New axle and a 5mm spacer for the left side. Check the how-to section of the Park Tool site. You will need to redish the wheel, too.
    mtbtires.com
    Just Ride!
    Reputation: Pigtire's Avatar
    Here you go...
    It's a Shimano 105 hub w/ a MA3 rim spaced to fit a 135 project 28er mtb frame. I just went to the bike shop and bought a longer axle and a 5mm spacer. Installing the axle and the spacer is a breeze but you need to take some time to redish your wheel so it will be centered over the hub. Still it was an easy & fun project.
    Reputation: Raymo853's Avatar
    I had to do this for my cross bike. I just put a ~ 2.5 spacer on each side and then did not re-dish the wheel. I choose that route since I have had bad luck trying to re-dish wheels in the past. But remember I am pretty incompetent in re-dish and truing wheels.
    Quote Originally Posted by Raymo853
    Interesting. How did that work out? What's the disadvantage of NOT redishing and doing what you did? I would suppose that it makes more of a "ghetto" freewheel since you have to use a cog w/ spacers, which is OK w/ me for now. That seems like less work for me and I can leave the wheel alone. When funds and time allow, I can track down a dedicated wheelset.
    Dec 1998
    Quote Originally Posted by oldskoolboarder
    Should work fine for a singlespeed. On a gearie it could screw up the chainline.
    mtbtires.com
    Thanks for the input all. Just picked up some 2.5mm spacers.
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. blast from the past, cut/paste from archived MTB DOC posts
    By ashwinearl in forum XC Racing and Training
    Last Post: 02-09-2005, 09:47 AM
  3. Passion Hit - Roadie Style! (LONG)
    By parkmeister in forum Riding Passion
    Last Post: 06-09-2004, 03:11 PM
  4. Training-what time logged on a MTB is equivalent to time on a road bike?
    By dawgcatching in forum XC Racing and Training
    Last Post: 04-28-2004, 09:23 AM
  5. Replies: 5
    Last Post: 03-05-2004, 12:37 PM
