convert help- Mtbr.com
Results 1 to 2 of 2
Thread: convert help
    convert help
    i have a soulcraft convert that seems to slip a little after every ride. I run a 34x17 ratio on my gt tequesta and although it can be ridden with no tensioner, to make the chain tight would require taking out 1.5 links. So i have a convert which held just fine on my previous single speed convert (yokota yosemite) but now seems to slip in the "push up" position. The chain doesnt skip off the rear cog, it jsut has that little bit of slack before catching, and that bugs me. Any advice?
    Reputation: jgmtbr's Avatar
    Good job! Skipping
    I assume this only happens when you really hammer on the cranks; correct? Pushing UP on the chain is the way to do it and you SHOULD still have a tiny bit of slack in the chain. A tight chain is difficult to turn. If you're hearing that horrible 'slipping' type noise, it may be the free body hub that is slipping, not the chain/cog. Have you tried a different wheel?
    For quite a while I thought it was the chain slipping when it turned out to be the freebody hub. I replaced that (and now service it more frequently) and the problem went away.
    Quote Originally Posted by dompedro3
    If you're not living on the edge, you're taking up too much room.
  1. buy or convert, it is a question.
    By mutex in forum Singlespeed
    Last Post: 04-15-2004, 11:30 AM
  2. buy or convert, it is a question.
    Last Post: 04-09-2004, 07:22 PM
  3. Want to convert '89 Giant Boulder
    By edeckerpc in forum Singlespeed
    Last Post: 03-22-2004, 07:16 PM
  4. What's needed to convert Hayes 6" to 8"?...
    By UPSer in forum Brake Time
    Last Post: 03-15-2004, 12:30 PM
  5. should I convert my road bike to SS
    By SS'r in Kansas in forum Singlespeed
    Last Post: 01-25-2004, 06:06 AM
