Convert Chris King Classic to SS?- Mtbr.com
Results 1 to 7 of 7
    Reputation: Dude!'s Avatar
    New question here. Convert Chris King Classic to SS?
    Hi,
    I just had disc tabs added to my Ibis SIlk Ti and now I have a good set of chris king rim brake wheels. I was thinking of putting the wheelset on my single speed. Currently I am running a paul word on the rear - should I just stick with that. It works fine. If CK would be a better option...What is the best way to convert the rear wheel to SS? Will a king cog fit on it? Does CK have conversion kit?
    Sort of....
    The King classic hub cannot be converted to a true single speed hub. What you could do is purchase 7 7spd spaces, a King Kog and run it this way. If you needed bolt-on you could up-grade the axle as well. For all this you might be looking at $100 or so. You can also up-grade your hub shell to run discs. If you know a shop that has the hub tool, or if you have it, you can purchase a new hub shell, pull all of your parts out and swap the shells. This is about $80 or so.
    B-
    Quote Originally Posted by Dude!
    Hi,
    Over the Hill
    Reputation: dstepper's Avatar
    I would spend the money on a Eno White Industries Freewheel.
    Kam
    Kam is offline
    A hopped on pop.
    Reputation: Kam's Avatar
    for your king hub, a king or endless cog would be great, then a bunch of cassette spacers, end cap and lockring.
    i'd give marshall at endless bike co. if he has you endless cog in stock, order it and add a few cassette spacers with your order.
    head to your lbs and order a cassette lockring and end cap thru wheels manufacturing.
    cool thing with running a cassette hub om a ss...easily adjustable chainline.
    cheers and nice bike!!!
    Reputation: itsdoable's Avatar
    Any standard hub can be SS'ed with a cog & spacers, just make sure you use a wide base cog if you have the Aluminium freehub body (Surly, King, Endless & Boone make them). Here's ny King ISO hub with an Endless Bike cog:
    <img src="https://gallery.mtbr.com/data/mtbr/516/234259Stickel_CK_endless.jpg">
    If you have a Classic hub, you'll need to convert it to disc with one of <a href="https://www.firstprinciples.ca/products.html">these</a>, or get King to replace the hubshell - but you're probably better off getting a new hub. If you have a Universal hub, just buy the disc adapter. If you have the ISO disc hub, well, you'er ready to go!
    Paul's hub with a White Ind. ENO freewheel would be a good route too.
    Cheers,
    Tom
    Squalor
    Somebody did it very cleanly....(not my bike, but very nice)
    but Diggin the 1 x 14 too
    Reputation: 2gears=1speed's Avatar
    ...spaced out...
    really nice - looks like one of them Pink bikes from Hollywood
    ...BOONE spacer KIT... one of the nicest out there...!
  1. Jeep King of the Mountain Announces Sites and Racers
    By David Horn in forum Downhill - Freeride
    Last Post: 05-09-2005, 06:37 PM
  2. Learning to Dirt Jump with Chris Duncan
    By Bike Daddy in forum California - Norcal
    Last Post: 03-14-2005, 04:44 PM
  3. Singlespeed: More or less efficient?
    By grumpstumper in forum General Discussion
    Last Post: 01-13-2005, 01:01 PM
