Conversion Question - NX Eagle + Chain...- Mtbr.com
Results 1 to 8 of 8
    Reputation: grc77's Avatar
    Feb 2019
    I want to convert my Timberjack NX to SS. It has the alternator dropouts, primed for conversion.
    The NX Eagle crankset is 12-speed, so I am trying to gauge the right chain size and rear cog to get.
    I am unclear on the compatibility on chain sizing, if I push forward with a cog & chain, should I go 1/8 or 3/32? Any other considerations I should be looking at?
    thx in advance...
    ~grc
    Your rear freehub is probably XD, so you will need either a conversion kit for XD, like the problem solvers Zinger (LINK) or an HG freehub for your rear wheel and a more standard conversion kit. I prefer steel cogs to Al, width isn't critical. With the Zinger kit you have more limited options for cogs, but it may be a bit cheaper than an HG freehub + HG spacer kit and cog.
    In my experience you can always run a wider chain on a skinnier chain ring, but not the reverse.
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
    Jun 2017
    Quote Originally Posted by Frs1661 View Post
    NX uses a standard Shimano freehub.
    Feb 2019
    My hope was to run the Surly SS conversion kit and an 18t cog. I plan to get a new chain, in the event I want to switch it back to a 12-speed.
    My question is if I need to a 1/8 or 3/32 hub. And the same for the chain size.
    Reputation: coleam's Avatar
    Quote Originally Posted by grc77 View Post
    Depends on what cog you get. Most are 3/32", but there are some that only work with a 1/8" chain.
    Sent from my SM-G950U using Tapatalk
    Quote Originally Posted by acedeuce802 View Post
    Nevermind then! A standard conversion kit will work well, so you are much better off
    I used to run 1/8 in chains but now I run 9 speed (3/32) chains. I've noticed no difference in wear but the 9 speed chains are lighter and supposedly stronger than most 1/8th chains.
    I would get a Surly cog and a 9 speed chain.
    Feb 2019
    Awesome - thx Frs...
    Deeper look is the bike has a Sun Ringle SRC 12x148 rear hub. From what I can tell its listed as Shimano compatible.
    The chainring is 32t; my approach was gonna be 32x18 running just shy of a 1.8 ratio. The Surly 18t 3/32 is plentiful for me to order.
    Thanks again for the quick responses... very helpful...
    ~grc
    edt
    edt is offline
    Reputation: edt's Avatar
    Mar 2017
    Surly recommends 3/32 for their cogs.
    I run a KMC 11 speed chain with Surly cogs and a non-Eagle NX crankset.
    My other ss uses a Surly cog with a 9 speed KMC (3/32) and flat ring Vuelta chainring.
  1. GX eagle chain as durable as XX1 eagle?
    By half_man_half_scab in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 4 Hours Ago, 05:03 PM
  2. best Drivetrain-- eagle or hybrid eagle?
    By SB Trails in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-12-2017, 05:11 PM
  3. SRAM Eagle chain with xx1 (non-eagle) chainring.
    By LyncStar in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-27-2017, 05:19 AM
  4. Federal Government / Bald Eagle and Golden Eagle death proposal.
    By DIRTJUNKIE in forum Off Camber (off topic)
    Last Post: 07-05-2016, 08:14 AM
  5. RockShox Ride Experience at Eagle Bike Park in Eagle, Idaho
    By lil29er in forum Idaho, Montana, Wyoming
    Last Post: 06-28-2012, 04:56 AM
Members who have read this thread: 22
