conversion kits- Mtbr.com
Thread: conversion kits
    conversion kits
    Is the Forte conversion kit to good to be true. How about Rockwerks on ebay??
    Is there a GOOD conversion kit out there??
    I'm new to SS so I want something that really works and won't be a pain the arse.
    I guess there isn't.
    I used the DMR it and haven't had any problems with it. The 16 tooth cog that came with it was a little steep for me so I used the 20 tooth out of my cassette.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Use a wide base cog , cut some spacers from 11/4" abs pipe , and the tensioner from price point is pretty decent . Narrow base cogs can damage your cassette hub , so its a good investment to get the wide base cog . If you buy spacers get the ones that are made up of a bunch of narrower spacers so you can adjust your chain line . You could also use a bunch of cassette spacers if you have them .
