Cog spacers going from 142 to Boost 148.- Mtbr.com
    Aug 2010
    I just switched from a 142 Nimble 9 to a Boost 148 Nimble 9. I was running a 6mm offset chainring on the 142 and have a 3mm "Boost" ring on the new frame.
    Can I run my cog spacers the same way in the new frame? I'm thinking everything moved the same amount so should be the same?
    * Using same crank, BB, and BB spacers as original frame.
    May 2010
    You can use the same method as seen here. Just substitute for the wider rear hub:
    http://forums.mtbr.com/singlespeed/c...th-738755.html
    Aug 2010
    So I just moved the same spacer setup to the new frame and it looks perfect in the stand. Shakedown ride will tell more.
    Reputation: bikeny's Avatar
    Sounds to me like the same setup should work. You moved the chainring outboard by 3mm, and each side of your hub moved out 3mm.
  1. Boost 148 rear on a 142 frame
    By Davide in forum Wheels and Tires
    Last Post: 09-29-2018, 11:16 AM
  2. 12mm x 142/148 boost rear ends
    By MannaDesigns in forum Frame Building
    Last Post: 03-10-2016, 12:40 PM
  3. Revealed: 148 boost weaker than 142!!!!!!
    By Davide in forum General Discussion
    Last Post: 02-07-2016, 01:21 PM
  4. Boost 148 conversion to 142
    By NullAndVoid in forum Trek
    Last Post: 12-31-2015, 01:11 PM
  5. Boost 148 to 142??
    By YodaForce in forum Trek
    Last Post: 09-16-2014, 03:33 PM
