Cog Questions- Mtbr.com
Results 1 to 10 of 10
Thread: Cog Questions
    Reputation: KavuRider's Avatar
    Sep 2004
    New question here. Cog Questions
    Hello all.
    I'm getting mighty sick of the gears on my Kona and I want to convert it to a SS. Its a Kona Sutra with the trick horizontal/disc mount dropouts, so tension isn't a problem.
    My big question is what cog to use. I have a Mavic Speedcity wheelset and I would like to go budget and simply convert the rear wheel with some spacers. I'm worried that a single cog will tear up the cassette body.
    I've seen some references to wider base SS cogs on here, but I would like to find one that I can get soon and isn't too expensive. Right now, Chris King is looking like the best option.
    Any suggestions?
    Cheers
    KavuRider
    Quote Originally Posted by azdog View Post
    I think he was born around the time of the Chernobyl fallout which would explain a lot.
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    the surly cog is a good 'inexpensive' option...i hesitate to use the word cheap.
    Expert of the Internet.
    BECAUSE I SAID SO
    Sep 2004
    Oops, you're right!
    Quote Originally Posted by nogearshere
    Yes, inexpensive, not cheap.
    Didn't think to look at that one! I do want their chainring though, go for an all steel drivetrain.
    Cheers,
    KavuRider
    34N 118W
    Reputation: Hollywood's Avatar
    ditto Surly
    Reputation: RetroG's Avatar
    Sep 2004
    Ok, think I'm set!
    Thanks all for the help!
    I'll post pics when she's all done!
    Cheers,
    KavuRider
    If your cassette body is steel you are ok with any cog
    I have been using "thin" $4 Novatech cogs on my Crossmax for months and you cannot see what position the cog was on the hub, absolutely no marking.
    Sep 2004
    I would rather not risk it...
    I've heard of people not having problems. But I don't want to take the risk.
    I just ordered a bunch of SS stuff up, so hopefully in two weeks I'll be up and running!
    Cheers,
    KavuRider
    byklvr
    Guest
    Hope King Cog or a Surly Cog...
    Both work fine. I got a King 17t as a freebie add-on with my hub order so I haven't shopped around. We sell the Surly Cog and people swear by them. The King is a lot lighter, and since I'm a sucker for bling, I'll run it until it dies and decide later, but for now, it's taken a serious beating and holds up.
    Reputation: Potential Roadkill's Avatar
    Endless cycles kick a$$ cogs
    Nice cogs for cassette hubs. What kind of gear ratio are you thinking about running? I took the rings off the rouleur crankset that came with the bike and found the 42t middle ring a bit much. Swapped it out for a 38 and am now running 38t-20t. Thinking about going with a 22 for climbing days.
    29er Fan!
