cog question from SS newbie- Mtbr.com
Results 1 to 5 of 5
    Reputation: bgfthntr's Avatar
    New question here. cog question from SS newbie
    I'm currently using a new cog (21T) from a Deore cassette and a new 9 speed chain. When I pedal backwards you can hear clicks and little clunks from the chain on the cog. Will SS specific (surly?) cog make a difference? It rides ok and I've been messing with chain alignment but doesn't seem to make a difference.
    Loving the SS thing by the way...
    thanks for you help...
    So you took apart a cassette and used one of the cogs? That's ok to do, but a ss cog will have a thicker base, meaning it won't tear up the hub as bad. If it's a crap hub you don't care about, it doesn't matter.
    openwound
    Reputation: voodoochild's Avatar
    I was recently experiencing the same thing, though oddly enough it was occurring with a King cog. I switched to a Surly and the noise went away. I thought it was chain line initially and spend a fair amount of time fiddling with that to no avail. Swapped out the cog and all is quiet.
    Try a Surly cog. As p_nut mentioned, the surly cog will also be nicer to your freehub body as it's wider at the base.
    thanks guys. Just ordered it and should be in end of week.
    I push my bike up hills
    Reputation: BMeX's Avatar
    Jun 2010
    It would be best to eventually switch to SS chain and chainring also.
