Chewing up my cassette freehub?- Mtbr.com
Results 1 to 21 of 21
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    Hi All,
    I'm running your standard, milk toast, pedestrian, everyman Shimano XT hubs and I'm worried about chewing/gouging in my freehub body. I'm using a Chris King cog and some Surly spacers.
    Is anyone making a replacement freehub body made from steel? I would happily take the extra grams for an indestructible freehub. I put a lot of pressure on the pedals when climbing.
    Does this exist?
    Nov 2015
    I don't know if it exists but I've got the same problem on my 2015 Trek SuperFly SS. The cogs need more meat where they meet the splines. I really kind of just liked my screw on BMX cogs from years past.
    Sep 2013
    I use Problem Solvers cogs and carriers and haven't had a single issue with freehub wear. Clever and awesome and they allow you to stash extra cogs on disc hubs since they use a 6-bolt pattern.
    I thought Shimano freehubs are pretty well always steel?
    Reputation: evenslower's Avatar
    I've run King cogs, Niner cogs and Surly cogs on a "standard" freehub. While they do mark it up a bit I wouldn't say it chews it up. Not a big deal, can still get a cassette off and on if needed.
    Merendon Junkie
    Reputation: abelfonseca's Avatar
    Dec 2011
    Quote Originally Posted by Slash5 View Post
    ^This
    At least I think its that way all the range up to XT, not sure about xtr.
    Reputation: Andy R's Avatar
    Nov 2008
    Plus, CK sprockets are pretty wide based anyway.
    May 2010
    No such thing as a durable shimano freehub let alone indestructible.
    Reputation: Acko's Avatar
    Feb 2014
    Endless Bike Co Kick Ass cogs have a super wide base and won't chew your freehub.
    They're alloy but last ages.
    Is it actually chewing up your freehub or are you just worried about it?
    Aug 2010
    The Shimano hubs on my beater work fine with crappy stamped cogs. Steel is real.
    Reputation: Mr Pig's Avatar
    I've not seen a Shimano free-hub chew up? Is this an actual problem?
    Hope ones, yeah...
    MaxTheCyclist.com
    Dec 2014
    Quote Originally Posted by Saddle Up View Post
    I chewed up my last ones with a cassette. I'm looking to nip the problem in the bud. Speccing out the bike for endurance racing and remote touring!
    I can buy an XTR Titanium freehub body through my LBS. Anyone know if it's compatible with an XT hub? Would rather not rebuild my wheel.
    Reputation: Saul Lumikko's Avatar
    Oct 2012
    Cheap cassettes would chew a freehub, but wide-based SS cogs won't.
    Merendon Junkie
    Dec 2011
    Quote Originally Posted by mdilthey View Post
    I think an xt freehub body will be stronger and more resistant to getting "chewed" than an xtr.
    MaxTheCyclist.com
    Dec 2014
    Quote Originally Posted by abelfonseca View Post
    The XT one is made from titanium. From what I can tell, titanium ones are damn near indestructible - YEARS of use without a mark.
    The steel freehub bodies do just as well. It only takes a slightly harder metal to resist the grooves.
    Unfortunately, XT hubs use an aluminum freehub body. It's easier to manufacture, and a bit lighter, but you can chew into it if you really pedal hard.
    I'm not saying "The XT hub is terrible" and I'm also not saying I can't use an aluminum freehub body.
    But, if someone else has replaced their XT freehub with an aftermarket steel/titanium one, or an XTR one, I'd like to know before I try to do it myself. If you haven't done this, specifically, there's not much else that can answer my OP! Sorry!
    Feb 2010
    My advice is to not worry about it. I use CK cogs on AC aluminum hub bodies and don't have any issues with gouging. And AC hub bodies are the softest out there I think.
    Unfortunately, XT hubs use an aluminum freehub body![/B]
    Confusing misprint is confusing.
    May 2014
    Quote Originally Posted by jonshonda View Post
    I thought the same thing. Too many Fat Tires?
    MaxTheCyclist.com
    Dec 2014
    Quote Originally Posted by solo-x View Post
    I think that's going to be my new plan.
    Feb 2015
    I use an Origin8 cog that has a nice wide aluminum carrier. I think I got it off of eBay for less than 20 bucks.
  1. Cassette loose on the freehub
    By Madd Get in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2014, 07:03 AM
  2. cassette/freehub friction when I spin cassette
    By Gabe3 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-23-2014, 08:15 PM
  3. cassette will not fit on freehub
    By Scott O in forum 29er Bikes
    Last Post: 08-18-2011, 09:13 PM
  4. Cassette freehub/question
    By Chase1996 in forum Wheels and Tires
    Last Post: 05-26-2011, 08:20 AM
  5. CK singlespeed cog chewing into ZTR freehub - dangerous?
    By one incredible donkey in forum Singlespeed
    Last Post: 03-06-2011, 11:33 AM
