Cheap place to get SS hub spacers?- Mtbr.com
Results 1 to 9 of 9
    offroader
    Dec 2008
    Call me weird but I think spending $20 on a 8 pieces of cut aluminum tubing is a bit much. Don't you? I remember paying 50 cents for each ring at my LBS a while back. Last I checked they didn't have any. Anyone know where I can find some on the cheap? I need enough for 2 bikes.
    Super Moderator SuperModerator
    Reputation: driver bob's Avatar
    If you want super cheap just use PVC pipe. It's ghetto but it works.
    poser Administrator
    Reputation: rockcrusher's Avatar
    Aug 2003
    I break apart old cassettes and use the spacers. Not pretty but it gets the job done. PVC as mentioned also works if you are bearish on old cassettes.
    MTBR Posting Guidelines
    calories>electrons
    CB2
    CB2 is offline
    Jam Econo
    Reputation: CB2's Avatar
    Quote Originally Posted by driver bob View Post
    I've done this. Find a metal spacer for against the lockring.
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    I believe that bottom bracket spacers also fit.
    one chain loop
    Reputation: fishcreek's Avatar
    Quote Originally Posted by AZ.MTNS View Post
    yes, but also more expensive. not sure why.
    i usually go to my LBS's recycle bin and take all the cassettes that i can, if i'm lucky there are BB spacers too and cassette lockrings. BB spacers are nicer (harder plastic) material and have lower profile.
    everything sucks but my vacuum cleaner.
    Reputation: monzie's Avatar
    Your local bike collective/co-op should have all the cassettes and BB spacers you could ever want, free too.
    Quote Originally Posted by Tone's View Post
    Id scrap the passion forum all together, its a breeding ground for unicorn milkers, rainbow chasers and candy cotton farters.
    Dec 2010
    I typically my just cut some on my lathe
    Nov 2008
    I also use old cassettes' spacers and 40 mm PVC piping.
  1. cheap spacers?
    By mattKHS in forum Singlespeed
    Last Post: 12-01-2009, 09:47 AM
  2. cheap/makeshift freehub spacers...
    By cha_cha_ in forum Singlespeed
    Last Post: 04-15-2009, 04:50 PM
  3. PVC pipe as spacers for cheap SS conversion?
    By jtcastillo in forum Singlespeed
    Last Post: 10-12-2008, 07:51 PM
  4. any place with really cheap tubes or cheap patches?
    By eman in forum Where are the Best Deals?
    Last Post: 09-27-2004, 07:36 PM
  5. Cheap hub spacers
    By Raymo853 in forum Singlespeed
    Last Post: 08-23-2004, 09:00 AM
