Cheap, long lasting (steel?) 32t singlespeed chainring- Mtbr.com
Results 1 to 8 of 8
    Are there any? i'm looking for one for my holzfellers and all i could find was a surley one for $30 and not from a website that i've heard of before (Speedgoat?)
    do i have other options?
    EDIT: found the same one on jenson, but is that the cheapest?
    Quote Originally Posted by Dictatorsaurus
    The way I see it right now, if my bike is too heavy, then I'm too weak!
    Tulsa
    Reputation: rojogonzo's Avatar
    not steel, i like this better than my surly though
    http://www.mtbtandems.com/Middleburn.html
    wherever you go, there you are
    Reputation: ianick's Avatar
    I'm a big fan of my Salsa chainring after bending my Surly.
    openwound
    Reputation: voodoochild's Avatar
    Speedgoat is a reputable shop, I've purchased plenty of stuff from them and found them to be good people to deal with.
    As for a steel chainring, I haven't had the experience myself but have read accounts on the forum of folks who've bent them. I haven't heard of this happening with an aluminum ring.
    Have you considered getting a ring from Homebrewed (ISAR)?
    is buachail foighneach me
    Reputation: sean salach's Avatar
    The Homebrewed steel rings look the burliest. I used to own a surly ring, and while it certainly did have lon lasting tooth profiles, it was way too easy to bend. Before the surly ring, the only other rings I had folded from pedaling were steel granny rings(while riding trials). Aluminum lasts long enough up front, and appears to be more impact resistant by weight.
    Reputation: Velobike's Avatar
    I have bikes set up with Surly rings and also a Middleburn Uno.
    With the Surly rings I run a polycarbonate chain protector, but I can't with the Uno. I reckon although the Uno chainring is stiffer, the setup with the Surly ring and protector would be better able to take an impact.
    Latitude: 5736' Highlands, Scotland
    I'm a Spot man, myself. I do run a guard though. Big teeth, no ramps.
    Well, sombody is sending me one for the price of shipping, we'll see how it works out! I also run a bash and i did consider a Homebrew, but i'm looking for super long lasting until i get a job, then it will be ISAR all the way around!
    Thanks for the replies, good to know that speedgoat is good!
