A cheap fixed or flip flop 26" wheel?- Mtbr.com
Results 1 to 22 of 22
    Reputation: 24601's Avatar
    OK, so I have been commuting for a while now on my SS converted steel Puegot MTB, but I would like to try fixed. Right now I have a cheap set of rims running some 26x 1.95 specialized nimbus ex with a SS spacer/cog set in the rear. My wife would litterally kill me if I got another commuter, so as much as I would like a road fixie, my only option seems to be a new rear wheel. Building one isn't going to happen for me as I am not ready for that, and I am looking cheap cheap cheap. It has to fit the tires I have now too.
    So, are there any real options or am I stuck with what I have. BTW--The bike had a narrower rear spacing (like 126, 129, I don't remember), but I spread the legs and forced the newer wheel in. It goes back to normal though when I take the wheel out. I prefer a bolt on axle too (quick release slides), but I have changed an axle before and did OK.
    Seriously, can I do this for $50? This inspires me to take some pics of the current setup to show off.
    I found my old post on this bike and the spacing is 126.
    Also, can I ride fixed with my BMX Primos? I love them for commuting as they keep my feet on the pedals well. I am not going clipless for my short commute. Would powergrips maybe be a good idea?
    Check 'er out. Sitting in the back of my classroom like she does every day. New racka nd fenders since my last post.
    Candlestick Maker
    Reputation: baker's Avatar
    The Surly Fixxer is ~$55 and will convert most Shimano cassette hubs to fixed. You'll need a cog and lockring, also.
    http://aebike.com/site/page.cfm?PageID=30&SKU=HU9020
    I don't know of any <$50 fixed 26" wheels, but maybe they are out there somewhere.
    baker
    That is cool, but I honestly have no idea how that works. Anyone have any pics of one installed maybe to help me visualize?
    Quote Originally Posted by 24601
    The piece replaces your freehub body (the portion of the hub on which your cassette rides) - you would remove your axle, use a 10mm allen to remove you freehub body, bolt this piece on in it's place, and replace your axle.
    Very cool. I like the idea. Anybody tried one?
    no fat chicks
    Reputation: iliketoridebikes's Avatar
    yes
    i have been using one for at least a couple years now on 2 different hubs, LX and XT disc.
    can't complain one little bit.
    and that's unusual for me.
    #1 NORBA elite singlespeed racer 30-34 age group
    Reputation: Hobine's Avatar
    4$ conversion
    Quote Originally Posted by baker
    baker
    You could just epoxy the inards of an old shimano cassette freehub. Cost $4 for JB weld and I can use cheap BMX cogs for changing gear ratios
    Reputation: oldskoolboarder's Avatar
    I have one on a Van Dessel I bought here. It currently uses an 18T freewheel but I just bought a track cog and lockring to try it fixed. Need to get a lockring tool/spanner first though.
    Is the lockring tool the same as is used on the lockring on my cassette? I have one of those.
    No, it's more like a bottom bracket tool.
    OK, I am going to bring this up again. After talking to my LBS, the fixxer isn't exactly as cheap as it looked because you still have to get a cog and lockring, not to mention install, re-dish, etc. So, I tried doing some searches for fixed 26" wheels, but I guess I don't really know where to look because I am having a hard time. I would like to find one around $100 if possible, since that is what the conversion would cost. If we could find one in 126mm that would be great too. Or maybe a decent cheap hub to do a build up maybe with one of those $15 hoops Jensen is clearing out.
    Just as a reminder, this bike is only my commuter and it is a very short commute (I could walk it if I cared to) so it doesn't need to be one of the bling ones I see some of you have.
    Thanks again for any help guys. I am so confused. I wish my LBS was more familiar with fixed but they aren't.
    Reputation: beaker's Avatar
    build it
    Considering your budget, I would look at building. Find a flip flop bmx hub on ebay, pick up a cheapie rim and some spokes and give wheelbuilding a try. The only tool you would "have" to own is a spoke wrench (use your brakes as a makeshift truing jig), and you should own one of those anyway. Wheelbuilding isn't easy, but it isn't that hard either.
    Are BMX hubs 126mm? Pardon my ignorance please.
    man, I just can't seem to find what I need anywhere. When I find hubs that are narrow they are the wrong holes (I have 32 and the rim I was looking at is 32) or they are 135mm. It is looking more like fixxer time again.
    Can anyone give me ideas of where to look?
    Sofa King We Todd Did
    Reputation: SpinWheelz's Avatar
    There's a Phil Wood hub that's exactly what you're looking for, but that goes for somewhere around $150. Try googling something like '126mm track hub' and see what comes up...
    http://www.nashbar.com/profile.cfm?c...eid=&pagename=
    Now I am getting somewhere. How about this one? It is 120, but could I space it to 126?
    IRO Cycle has a 126mm track hub with 42mm chainline for $40 www.irocycle.com. You're still going to end up around $150, even if you buy all the parts and build yourself.
    Hub, rim, spokes, nipples, cog, lockring, spoke wrench, shipping for parts.
    OK hopefully I have this now.
    http://www.nashbar.com/profile.cfm?sku=12032
    that hub
    that rim.
    All I need are spokes and nipples. I have no idea about what to order for that, might just take the above to the shop and let them help me unless someone can tell me.
    Also, one shop said they would do the build for $35, but if I built then took tot hem for a true they would probably charge almost the same because I had built it and it would be more work than a standard build. Should I just pay for the build? I wish I had a truing stand but that just isn't going to happen.
    what you need to do
    is pull off the casette body and have a buddy weld it for you, i had it done and it didnt cost me anything. the bike shop hooked me up with a cog and spacers so try to pull that on em to, buy some beer and give it to them
    Quote Originally Posted by I Like Bikes
    I am not going to do anything to my current cassette, plus as I have already said I am trying to go back to the original spacing. I don't drink either.
    Reputation: Hurp1's Avatar
    Nov 2014
    https://www.purefixcycles.com/produc...-fgfs-wheelset
    $69 fixed freestyle wheelset. Doesnt say the spacing but I need 126 as well and just bought the set. 10 years later and we may have solved this
  1. Welcome, here's your 29er FAQ thread!
    By ncj01 in forum 29er Bikes
    Last Post: 06-20-2012, 01:56 PM
  2. how much bigger: cross wheel in 26" frame
    By dRjOn in forum 29er Bikes
    Last Post: 09-15-2004, 06:17 AM
  3. cheap fork that would fit a 26" wheel, and a BMX frame
    By antonovc in forum General Discussion
    Last Post: 09-09-2004, 12:53 AM
  4. Thinking of custom frame, 29" frnt, 26" rear wheel...
    By schnapmaster in forum Singlespeed
    Last Post: 04-29-2004, 05:09 PM
  5. flip flop disks
    By chirider990 in forum Singlespeed
    Last Post: 02-11-2004, 11:07 PM
