CHAMELEON rear tire size?- Mtbr.com
Results 1 to 8 of 8
    Aug 2005
    For anyone who owns a Chameleon, what is the largest rear tire width that it will handle? I'm thinking about getting one and want to know if I can put some wide tires on it.
    Thanks in advance for taking the time to respond.
    King Pin
    Reputation: xrmattaz's Avatar
    Good job!
    My Chameleon would happily accept a 2.4" Mutanoraptor Race tire.
    Aug 2005
    Quote Originally Posted by xrmattaz
    Thanks xrmattaz
    Apr 2005
    You could easily fit a 2.5 on there. I used to run 2.5 Hookworms.
    Reputation: FrontRanger's Avatar
    I can just barely fit a Panaracer Fire FR 2.4 which measures closer to 2.6.
    ٩(͡๏̯͡๏)۶[$̲̅(̲̅ιοο̲̅)$]
    Reputation: MondoRides's Avatar
    2.3-2.5" Depending on the tire...
    I also run a 2.4" Mutanoraptor Race with plenty of clearance but in the winter months I run a Gazzaloddi Dual 2.3" tire which barely clears.
    Reputation: msiddens's Avatar
    2.5!!!! Mine was rubbing on the Panaracer Fire 2.4 so I had to pull it and pare down to a 2.3.
    Click That Sh*t
    2.5 Weirwolf
    works fine.
