chains- Mtbr.com
Results 1 to 17 of 17
Thread: chains
    Reputation: 1-bar's Avatar
    chains
    I did a search and I only found a couple of peps who are running the Sram PC991. Can anyone recommend against using this chain for SS use? In terms of strength, I use this on my geared bike and typically mash on it like a SS so I can't see why I shouldn't use it for my dedicated SS. Thanks for any input.
    Got LEFTY?
    -2017 C’dale Scalpel Carbon 3
    -2016 C’dale Slate Force 1
    -2014 C’dale Bad Boy 1
    Reputation: Treybiker's Avatar
    991 works. Way better than the crappy PC-1 too.
    Quote Originally Posted by 1-bar
    Great chain. But also massive overkill for an SS. There's no reason (other than being a weight weenie, and there's nothing wrong with that) to run a high-end 9spd chain on an SS. Buy a decent 8speed or BMX chain for 1/4 the price.
    Reputation: stevereeneo's Avatar
    I think thecrazyfinn said it best...
    "here's no reason (other than being a weight weenie, and there's nothing wrong with that) to run a high-end 9spd chain on an SS. Buy a decent 8speed or BMX chain for 1/4 the price."
    Also the PC-1 is a notoriously BAD chain - I've snapped 2 and seen LOTS of broken chains on and off the trail... I have had excellent durability with 8 speed chains. An 8-speed chain seems to be stronger and way more reliable than the PC-1, and a bit more - but not quite as - spendy as a 9-speed chain...
    I've been using a SRAM PC-58 for a while... they're solid!
    S
    "You know how they make aluminum bike frames? They take steel and suck out all the soul..."
    I do get tired of saying this, but here it goes:
    If you have a good chainline, the narrower chains work better as they do not have as much side to side play on the cog/ring thus bind less and last longer. When you are cranking up a hill, you have a little frame flex, and your chain will want to creep a little. I've gotton my money's worth out of 9 speed chains lasting longer, and have been trying a Sram 10 speed to see how it does. 3.5 months and so far so good.
    hey guys, thanks for all of your replies. the pc991 hollow pin is done deal for me now.
    Got LEFTY?
    KMC bmx chain, they last forever. I fully agree that the PC-1 is total crap
    nobody reads your blog
    Apr 2005
    Quote Originally Posted by 1speed
    And they come in fancy colors. I will have to try a more narrow chain though too.
    don't try this at home
    Reputation: moschika's Avatar
    agreed. the "Z" chain in either the red or blue box(don't know what the dif is really, which ever's in stock i'll take it) at $8.99 is the best way to go. i think i've only had to replace the chain a couple times in the past 8 years of ss'ing.
    will you rep me?
    KMC Z610HX and done!
    Why spend more?
    Z chain - red box - rocks!!! You'll be running quiet as ever, almost stealth like.
    Bike Building and Painting
    Crystavox Single Speed Bikes
    Misfit Psycles
    Reputation: nogearshere's Avatar
    Mar 2005
    Quote Originally Posted by eischman
    if you look hard enough you'll find the Z610HX is available in colours...one of the few 3/32" chains that are.
    TADA...spam
    Expert of the Internet.
    BECAUSE I SAID SO
    I use SRAM 8 speed chains with no fuss (PC 58 or 58).
    They are really cheap, strong, use a Powerlink and do not rust.
    Most of French singlespeeders do indeed.
    Reputation: dirtdirt223's Avatar
    Mar 2006
    sram 8 speed chains are all you need. the pc 1's are crapola.
    Old, stale, negative
    Reputation: bstrick's Avatar
    KMC710SL is on both of my rides. I'm 2 bills and mash pretty hard. I broke 2 PC 1s. Good luck.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    PC-1, good and bad...
    There are two versions of the PC-1. The nickle plated version is a great chain that I've been using for about 5 years and goes for about $18. The non-nickle plated for about $9 is junk.
    Folks spout all the time about the PC-1 and rarely mention which version they speak of.
    Reputation: trekbuddy's Avatar
    Yeah I have the nickle PC-1 and have been happy all season........
    So far......
    Don't talk back to Darth Vader or he'll getcha!
