Chainring - Steel or Aluminum - which is stronger?- Mtbr.com
Results 1 to 12 of 12
    I just bent my 4 bolt surly chainring in half and from what I have read this has happened to other people as well. I am wondering what an alternative would be that would be stronger and prevent this from happening again? Would an aluminum ring be a better choice?
    Reputation: boomn's Avatar
    yep, the available aluminum ss rings are stiffer. Salsa and Blackspire are both nice
    from what i've read, steel rings can be made stiffer than those Surly's by using a better grade of stainless steel. I think ISAR uses a different alloy for his chainrings (see the homebrew thread in this SS forum)
    or you can add a bashguard
    General industry guy
    Of course aluminum will wear faster than steel. I've bent my Surly ring a few times - usually trying something I shouldn't - but have always been able to bend it back. I've not bent mine in half, though. The good thing about the steel? I've been through many chains on this one ring and there is no appreciable wear. On my last aluminum ring, I wore it out in one chain's worth of riding time.
    Alison Dunlap Coaching
    When you're not paid to ride.
    Reputation: smaxor's Avatar
    Dec 2004
    If you get Alu, at a light weight bashgaurd for extra piece of mind
    aluminum spiders with steel teeth
    i once saw one with that uber hard titanium nitride coating on them... looked awesome!
    Seeeriously easy Livin
    Reputation: Flystagg's Avatar
    Nov 2006
    Better yet titanium from Isuckatriding
    Dinner for wolves
    Reputation: buddhak's Avatar
    The 4-bolt spider is at least partly to blame, IMHO. 5-bolts 4ever.
    Responds to gravity
    Mtbr Forum Sponsor - Homebrewed Components
    That ring is a 304 grade stainless which has a very low yield strength, much lower than aluminum. This means that it bends like butter. I've tacoed one years ago just by climbing a hill, and i know im not the first or the last. Also, i've had teeth bend 90 degrees on many occasions. All it takes is your chain looseining up a little on a ride, and a little pedaling down a bumpy trail.
    For this reason, i will not make stainless chainrings. I do make stainless cogs, but i use a much higher grade of stainless that is heat treated. To use that same stainless for chainrings, they'd cost as much as ti, which wouldnt make sense to buy (hey, that rhymes).
    Does Ti last as long as the stainless? I'm thinking about Ti chainring and cog, but the $$$ made me balk. If, however, they last a long time (like my surly SS cog), then I would buy 'em for sure...
    Reputation: asphaltdude's Avatar
    Mr Tomicog makes nice stainless rings, too.
    Ride more!
    Quote Originally Posted by fatdave
    ti has a higher yield strength and tensile strength than stainless by a bit, so it will actually last longer. I dont think i've heard of anyone wearing out a 6al4v ti (like Boone's) chainring yet, but if someone has, please let us know how long it lasted, and if you kept up on chain replacements.
