Chainring size vs BB spacers- Mtbr.com
Results 1 to 5 of 5
    Nov 2016
    After building up my first SS, I'm trying to find the right gear ratio. 32/18 (1.78) is working great, but I'm looking to move up to 2.0 for some of the flatter trails. The plan was to move to a 36/21 (1.8) for normal riding and 36/18 (2.0) for flat trails. However, I have concerns about chainstay clearance with the 36t chainring. It looks like I'll need an extra BB spacer. As long as I fix the chainline, is there a rule-of-thumb about the maximum number of BB spacers? Minimum # of treads on the BB?
    Other option could be to go with a 16t in the back, but I worry about not having enough teeth engaged in the back. My tensioner only works in push-down due to geometry.
    Suggestions?
    Downcountry AF
    Oct 2013
    I'll take a crack at it. One spacer should be within the acceptable range unless you already have two spacers on the drive side and are at the limit.
    What BB and crank are you using? If you think you need more threads engaged there are some options if you dig around. Like the Raceface X-type Team DH threaded BB (for Shimano style spindles or 24/24), it has a longer threaded part for deeper insertion into the BB shell and would allow you to run an extra spacer.
    Rigid SS 29er
    SS 29+
    Fat Lefty
    SS cyclocross
    Full Sus 29er (Yuck)
    Reputation: socal_jack's Avatar
    Dec 2008
    If you have a direct drive chainring, try flipping it, did that on my ROS9+ for tire clearance works great.
    Canfield Riot SS
    ROS9+ SS
    ROS9 SS
    GT Peace 9R SS
    Nov 2016
    I've got a Raceface N/W crank and BB (initially was going to run 1x11, but thought better of it). Without tearing the drivetrain apart, I'm not sure if the chain will have clearance from the crank if I put the chainring on the inside of the spider. Maybe I'll give it a try and see.
    From what it looks like, I'd need 3-4 BB spacers leaving it as-is. Flipping the chainring seems a much better idea.
    Reputation: bikeny's Avatar
    Quote Originally Posted by HaolErik View Post
    I'd think 3-4 spacers would be way too much. The other crank arm would probably hit the frame too. They also make flat chainrings, which should offset the chainring 6mm or so.
  1. XT m8000 1x11 chainring spacers
    By DimitrisCSD in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-15-2019, 08:04 AM
  2. Spacers for 22 tooth inner chainring on XTR M980 10 Spd triple chainset
    By lloydgoodman in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-10-2016, 03:31 AM
  3. Need help guys- chainring spacers
    By jdaigneault in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-23-2015, 12:34 PM
  4. Where do I find the spacers/shims for a 34 T oneup chainring?
    By jgdblue in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-06-2015, 01:17 PM
  5. SRAM GXP spacers needed???? Size?
    By rydbyk in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 11-12-2011, 06:59 PM
