Chainring bolts threading on one ring- Mtbr.com
Results 1 to 6 of 6
    Got the chainring I wanted for my SS conversion and the old chainring bolts wont fully thread/seat on just one chainring (old road bike conversion, previously two chainrings). Is there something easy I can do? I only need a couple more turns but they are fully threaded as is.
    Retro Grouch
    Reputation: aka brad's Avatar
    Best to get new chain ring bolts..
    Quote Originally Posted by scout
    Chainring bolts come in 1 ring, 2 ring and 3 ring size. You have the 2 ring size. Check out your LBS or WEB store and buy some 1 ring size.
    1G1G, Brad
    Just one more rep and I get the toaster!
    Nat
    Nat is online now
    Reputation: Nat's Avatar
    Reputation: miSSionary's Avatar
    Jun 2005
    Do what has been suggested or go to the LBS and see if they have any spacers, though this option is not as good as scout and akbrad's suggestions.
    Black Sheep...where it'ss at!!
    "I'm not known for my patience. Patience is a polite quality and often appropriate, but it rarely gets things done. Impatience, however, is the hunger for results and intolerance for excuses and delays." LA
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    with the current bolts, you can use spacers or a bash ring... I used a bashring for some time
    and recently replaced the stock screws with these (cheap - $1 each - and light) https://psyclestore.com/product_info...roducts_id=163
    Cool, thanks guys. I knew there had to be an easy way and I'd get the answer here.
