chainring bolts- Mtbr.com
Results 1 to 5 of 5
Thread: chainring bolts
    mvi
    mvi is offline
    chainring bolts
    Removed a chainring from my crank. How do I shim the crank bolts now having to clamp only one ring?
    surly inbred
    Reputation: TroutBum's Avatar
    New bolts are in order.
    ie. new bolts with less threads
    Custom User Title
    Reputation: ew505's Avatar
    Or spacers. Check your LBS- they should only run you a coupla' bucks.
    Mar 2005
    The real pain in the ass is that you need a chain ring bolt spanner to tighten them down properly.
    Reputation: FlatFender's Avatar
    dremel.
