Chain tugs on a SS with a QR...- Mtbr.com
Results 1 to 11 of 11
    Mar 2006
    Just built up a Surly 1x1 and I am using a QR hub (with a good old 'crank it up tight' Shimano QR) on the rear. I have thought of using a chain tug on the drive side especially as I may ride it fixed sometimes.
    Anyone using this set-up?
    Most of the chain tugs are made for a 3/8" axle - it would not be difficult to make one to fit the QR spindle but what concerns me is that the serrated end of the QR would be replaced by effectively a flat washer, I could add a serrated washer in between I guess...
    Actually Surly's tugnut comes with a QR adaptor (washer).
    SSasquatch
    Reputation: galleywench's Avatar
    I am using the surly tug with QR adapter (drive side only), it works fine.
    Reputation: dirtdirt223's Avatar
    Mar 2006
    i have a qr and two tugnuts on my 1x1 which also has disc brakes. it seems no matter how tight the quick release is, the non-drive side always backs off of the tugnut atleast a mm or more after a ride. i have come to believe that the forces of the disc brake are pulling the non-drive side back.
    Mar 2006
    Thankd for the quick replies guys - the Surly tug nut is a nice piece for sure but here in the UK it costs 25 ($46)...
    I have a Tug nut on the drive side only. I see the same drift on the rear axil. I have track nuts too. My rear axil moves under load as in climbing a steep hill. I have had to stop and reset the wheel after a hill climb to keep the disk brake from rubbing. Loosen the nondrive nut and the wheel pops back ( the frame was wound up?). It seems like if the brake pressure was going to make the wheel move it would be backward not forward. My bike is a steel IRO Mia with Promax Disks (slows).
    Two tug nuts would fix it. Bottle openers on both sides.....
    Exclusively Single
    Reputation: long hazy daze's Avatar
    I think you can buy the QR adapter/washer for the Surly tugnut seperately. i know I've seen them somewhere, shouldn't be hard to find from any QPB dealer. You can then use the adapter with any old tensioner.
    As far as the teeth on the QR interfacing with the dropouts, being that there is a tugnut/tensioner, it becomes a non-issue because the tensioner is holding the axle in place, so you don't have to rely on the teeth of the QR gripping the surface of the dropout.
    Exclusively Single
    Quote Originally Posted by Biker Bob
    A brake-side tugnut will not keep the axle from sliding backwards in the dropout. Not much you can do about disc brake-induced-rearward-axle-sliding other than making sure the QR or nuts are tight enough. That's a big advantage of sliding drops or a vertical drop/ebb setup, because it eliminates this problem. That being said, I still prefer the simplicity and function of horizontal drops/fork ends, just have to make sure the QR is tight enough.
    what is this QR adapter for the surly tuggnut?
    Quote Originally Posted by alexb618
    It's that washer looking thing on the right...
    on my 3rd wind...
    Reputation: SingleTrackHound's Avatar
    Jul 2003
    Will using one of these with tugnut and ditching QR help?
    http://aebike.com/page.cfm?PageID=30...ils&sku=QR8000
    sth
