Chain tensioner recommendations- Mtbr.com
Results 1 to 12 of 12
    I have a Niner Air9 RDO which I love but not the best bike to set up SS. It requires a chain tensioner and I've used a Singleator and Forte ones in the past but the spring over time seems to weaken. Someone in another thread recommended a DMR tensioner and the Blackspire Stinger which both look like good options. I'm guessing the Stinger will work with a BB30 and the low chainstays on my Air9.
    What would you recommend out of those two and are there any other options I should look at?
    Edit: After looking at the Blackspire setup, I don't think it'll work on my Air9. I need something that pushes the chain down and doesn't pull the chain up because the chain will rub against the chainstays.
    Mar 2011
    I've used the Sette version of the DMR tensioner from pricepoint for a while now. Haven't had any issues with slippage.
    SS Pusher Man
    Reputation: mtnbikej's Avatar
    Sep 2001
    If it is a BB30....why not just use the BioCentricII EBB?
    Bicycles donít have motors or batteries.:nono:
    Ebikes are not bicycles :nono:
    Quote Originally Posted by irv_usc View Post
    Good to know thanks.
    Quote Originally Posted by mtnbikej View Post
    Oops, I meant it's PF30. I could still get an EBB for it from Wheels Manufacturing, but I'm not sure if those are more prone to slipping and creaking (both issues that I tend to have problems with because I'm 185 and really try to hammer on the cranks). Also, there's very little clearance if the chain is a direct line from the chain ring to cog.
    MaxTheCyclist.com
    Reputation: mdilthey's Avatar
    Dec 2014
    I got a Paul Melvin... it's beautiful...
    Ultralight bikepacking and gear lists... MaxTheCyclist.com
    Life's a Garden, dig it!
    Reputation: chuckha62's Avatar
    The Soulcraft Convert, if you can find one. Slick set up.
    "And crawling on the planet's face, some insects called, The Human Race..."
    SS Pusher Man
    Sep 2001
    Quote Originally Posted by bank5 View Post
    Personally, if the frame can be run without an external tensioner, I would go that way first. Derailluer hanger mounted tensioners are prone to rock strikes and bent hangers.
    KgB
    KgB is offline
    SNGLSPD
    Reputation: KgB's Avatar
    I have had a wheels eccentric for over a year now, no creaking no slipping no problem
    Sent from my XT1080 using Tapatalk
    I've been inside too long.
    Aug 2010
    I'd go EBB first, if not, then DMR.
    I emailed Soulcraft a while back trying to get one of theirs & never heard back. They still in business?
    Soulcraft is still in business. I called them and went to voice mail. Sean called me back within a half hour and even though I bought my Convert used on Ebay, he asked what all I had and sent me pieces I was missing for ten bucks. Couldn't have asked for better service than that.
    i have a tensile and it rocks. a 22t cog just barely fits tho
  1. 1x Chain Tension???
    By cycljunkie in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-05-2014, 07:48 PM
  2. Best Single Speed Chain Tension / Chain Guide
    By bank5 in forum Singlespeed
    Last Post: 06-24-2013, 07:16 AM
  3. SS MTB used for CX - chain tension
    By SSki in forum Singlespeed
    Last Post: 09-18-2012, 11:43 AM
  4. Chain tension / chain slap
    By MrAitchGee in forum General Discussion
    Last Post: 08-28-2011, 03:50 PM
  5. problems with chain tension with chain ring.
    By Rad Rider 415 in forum Singlespeed
    Last Post: 08-14-2011, 08:34 PM
