Chain tensioner for broken derailleur hanger?- Mtbr.com
Results 1 to 14 of 14
    Bite Me.
    Reputation: cutthroat's Avatar
    Hey out there - my nephew broke the derailleur hanger on his bike, and it's not replaceable (it's part of the drop out). The bike has vertical drop outs. The frame is nice and worth salvaging. The only option I see is to convert to SS, and he's excited about that. Are there there any tensioners out there that bolt into the QR on the rear axle? I know there are some that attach to the chainstay, but they look a bit flimsy. Any other options? Thanks
    When I see an adult on a bicycle, I do not despair for the future of the human race. ~H.G. Wells
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Yess Products etr-b, tensioner attaches to bottom bracket . Available at Price Point .
    Bite Me.
    Quote Originally Posted by AZ.MTNS
    $60! - Not. Any other options?
    Reputation: boomn's Avatar
    Way to be thankful for the help
    That Yess tensioner is the only one I've seen that doesn't attach to the hanger and actually works well. There are other options besides tensioners (WI eccentric hub, forward components EBB) but they are all more expensive.
    There are tensioners that go on the QR, but the QR clamping force alone isn't enough to hold a tensioner from rotating so they all use a second bolt into the derailleur hanger to tighten it in place after adjusting.
    If all else fails, try to find a magic gear
    Bite Me.
    Didn't intend for that to come across rude. The cost is more than the bike's probably worth is all. I'm considering picking up a replaceable hanger that is close to matching the dimension of the drop out and then busting out the dremel, file and drill and seeing if I can mount a replaceable hanger on the drop out - otherwise the magic gear may be the best option.
    You could try a ghost ring...
    Stache 7 --- Rigid Surly 1x1 B+ --- Dirt Drop CrossCheck
    Moderator Moderator
    Try the magic "ratio" (ask the forum if anyone has found one for your frame). If that's not feasible, I've seen hangers sucessfully "grafted" to the broken stub. Find the correct drill size, then use Shimano chain pins to attach the piece (OS Bikes by Mark Slate uses this method on their SS/geared frame).
    i was just about to say ghost ring! if you have a few random chainrings laying around then it's free.
    looks cool too
    get a sette tensioner. it replaces the scewer nut with its own. then ziptie the arm to the correct tension
    http://www.pricepoint.com/detail/170...-Tensioner.htm
    Quote Originally Posted by fishywishy
    genius idea! For push up mode that should work
    Reputation: Dremer03's Avatar
    This should work good. The bolt only acts as a pivot so as long as the skewer is nice and tight there shouldn't be a issue with that tensioner or one like it. Avoid a spring loaded tensioner, they rarely work and wont work at all for your situation.
    Big Foot Blue KHS XC704r
    Quote Originally Posted by Vtolds
    kinda... the skewer actually acts as the pivot and the bolt is what provides the primary clamping force. The zip-tie is what will provide the clamping force in this new case. Sorry, I'm too pedantic sometimes
    Quote Originally Posted by boomn
    I bet your right. I own one of these tensioners, but I only ran it once before I geared my bike so the memory is a bit fuzzy. Zip tie it up that should work. You should have a look at ebay or craigs list for a used frame, might find one for as much as the tensioner costs.
    Not sure if yu weld or know someone who does, but that'd be pretty easy to weld back on.
