Which chain tensioner?- Mtbr.com
Results 1 to 8 of 8
    Reputation: 1-bar's Avatar
    I'm resurrecting an old flame which is my Mamasita. It's currently on magic gear consisting of a 32x21 setup. The chain seems a touch too slack although I really doubt it will jump out of gear. The teeth on the rennen chain ring and rear cog are deep. Anyhow, I'm looking for opinions on either a renned push/fixed style or a spring loaded type from sette. I'm leaning towards the push type but I'm open to opinions based on the chain tension that you can see from this photo.
    Got LEFTY?
    -2017 C’dale Scalpel Carbon 3
    -2016 C’dale Slate Force 1
    -2014 C’dale Bad Boy 1
    local trails rider
    Reputation: perttime's Avatar
    Aug 2005
    My Rennen tensioner has been totally reliable. The only drawback is, it complicates wheel removal a bit.
    "it IS possible that you are faster or slower than anybody else who is having at least as much if not more or less fun"
    There are soo many good tensioners available now. The Rennen is great, as is the Yess ETR/B, the Phil Wood Philcentric, and the WI Eno Eccentric.
    Jan 2009
    I tried a Surly and I didn't like the the spring feature. I busted the spring rather quickly. the DMR I got laver worked fine on a few SS conversions I did.
    Reputation: Houndog45's Avatar
    Oct 2010
    I second the DMR...
    Yup, I used a DMR for a while myself. It's good stuff, and works very well.
    The dmr looks like a good alternative to the rennen, but I'll probably go rennen if I go to a push style tensioner. I'm using the rennen cog and chainring...
    I like the idea of the Phil wood eccentric or exzentricker but both are pretty pricey. My limit would probably be about $200 if anyone knows how to get one in that price range.
    Given the small amount of tension I need, do you think a spring loaded type will work better than the push style?
    Got LEFTY?
    There are some nice ones here too...
    http://forums.mtbr.com/singlespeed/p...rs-226049.html
  1. Replies: 17
    Last Post: 05-18-2011, 09:04 AM
  2. Kore Chain Reactor chain tensioner
    By djork in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-08-2009, 06:52 PM
  3. Replies: 10
    Last Post: 05-14-2009, 06:09 PM
  4. Chain Tensioner VS. Half Link Chain
    By EndersShadow in forum Urban/DJ/Park
    Last Post: 03-29-2009, 05:04 PM
  5. Chain tensioner vs chain guide for rohloff
    By krolik in forum Internal Gear Hubs
    Last Post: 11-07-2008, 04:44 PM
