chain tensioner- Mtbr.com
Results 1 to 9 of 9
Thread: chain tensioner
    Reputation: hrhitter's Avatar
    Dec 2004
    chain tensioner
    I've got a 29er monocog and I'm running a race face diablo crankset with a 22 32 bash gaurd.
    I want to be able to switch between the 2 front rings without switching the chain.
    I'm not strong enough or light enough to leave it on the 32t ring yet.
    so depending on what trails I ride I'm R2 chains
    whats your opinion?
    Reputation: boomn's Avatar
    Quote Originally Posted by hrhitter
    whats your opinion?
    I don't think your dropouts are long enough to account for a 10t difference in chain length between those gear combinations.
    What size rear cog are you using? A 22t chainring with most any cog size sounds extremely low for singlespeeding. I think you would be surprised how well a 22t rear cog works
    Dec 2004
    My rear ring is a 20T
    I realize it is low geared but I'm 6'7" 320 and am riding steep hills that I enjoy being able to climb.
    OK, makes sense.
    To be able to use the same length chain with two gear ratios, the cog size has to change as well. If you find the right combo its doable. For instance 24x22 (very close to your current 22x20) and 32x14 would use the same length of chain, which would give you a hill gear and a road gear.
    Enjoy your ride
    Reputation: Nater's Avatar
    Paul's Melvin clains you can run two chainrings with up to a 20 tooth difference. Might be the tensioner you need?
    www.paulcomp.com/melvin.html
    Quote Originally Posted by Nater
    Good idea. Running a tensioner on an SS frame goes against my normal standards, but that would allow the OP to do what he originally asked
    EDIT: oops. The Monocog does not have a derailleur hanger. The Melvin would require some sort of add-in hanger for horizontal drops
    Ride Responsibly
    Reputation: LWright's Avatar
    I ran a two speed manual shift for a while with a Melvin, works very well, as it should for the price.
    One thing, even though it adds all the stuff a SS tries to eliminate, a front derailleur helps. Changing that chain by hand gets old real fast.
    Another option you may want to consider is going 1x9. Not knowing if the Mono has a hanger or not?
    WWYD?
    Reputation: johnnyb's Avatar
    Quote Originally Posted by LWright
    Mono doesn't have a hanger but you can do this.
    http://www.bikeman.com/FS3102.html
    I just ordered one and can't give you a review yet but it looks promising.
    Dec 2004
    that looks like a good option what tensioner will you use?
    LMK how it works out.
