chain tension w/ chain tugs on track ends- Mtbr.com
Results 1 to 5 of 5
    I just received some inexpensive, but good RL tugs for my Dawes SS. Exactly how much tension should be on the chain?
    Forgot to mention I got Shimano Deore closed cam skewers.
    Check the Park tools website http://www.parktool.com/repair/readhowto.asp?id=27
    It explains tension pretty well.
    habitual line-stepper
    Reputation: kanai's Avatar
    you can check out sheldon brown's website as well:
    http://www.sheldonbrown.com/fixed.html
    i'm still trying to figure it out myself. i thought i had the tension dialed in after i installed bb5's on my monocog, but two-thirds into my next ride, the chain started skipping. so i dismounted and tightened the tugs, only to drop the chain shortly thereafter. after that, i pulled the tugs off and started over, including recentering the rear disc brake. it felt tighter than i'd think would be okay, but i didn't drop the chain on the way out. good luck!
    Quote Originally Posted by vBulletin
    The server is too busy at the moment. Please try again later.
    Ovaries on the Outside
    Reputation: umarth's Avatar
    This could be best answered from the likes of Salach or booomn or whoever. Assuming you have a straight chainline and a fairly round chainring, I think a half inch of movement in the chain is pretty acceptable. If you ride somewhere, look at your bike and notice the chain is sagging, you have done it wrong.
    Thanks guys. Pretty much dialed in now.
